1/350 RICHELIEU Dakar 1940-41
- Channell
Re: 1/350 RICHELIEU 1940 in the harbor Dakar
Remember you have to improve on the last one... this one should have working 1/350 nanobot sailors roaming the decks and functioning AA guns that fire miniature flak to stand a chance of outdoing your other Richelieu.
-Jason Channell
- LE BOSCO
Hello Jason
A nano crew ,a very good idea
thank you for the tip
cheers
nicolas
cheers
nicolas
- Christian M.
- Location: Cologne / Germany, sometimes Poznan/ Poland and Chessington/ UK
Now I understand everything, why Nicolas is making so great models!Channell wrote:Remember you have to improve on the last one... this one should have working 1/350 nanobot sailors roaming the decks and functioning AA guns that fire miniature flak to stand a chance of outdoing your other Richelieu.
J. Aguilar
hi Nicolas
Good start for another great model. what measures of dio?
cheers
JAM
cheers
JAM
- LE BOSCO
Jam and Christian, thanks for your comments
Jam for my dio ,there is nothing of arrested, but ,it will do a minimum of 85cm by 50cm
a small diorama somehow
cheers
nicolas
cheers
nicolas
- DWD
Hey Nicolas. What kind of camera do use to take your photos?
Doug
Currently building:
viewtopic.php?f=59&t=120496
Currently building:
- LE BOSCO
DWD wrote:Hey Nicolas. What kind of camera do use to take your photos?
I mainly use two camera Cannon a compact A520 and a EOS 1000D,this is far from being a pro equipment
best regards
Nicolas
- PetrolGator
It is always a wonderful pleasure to watch one of your builds evolve.
- Chris
1/700 Murdertorpedoboat Ooi
- LE BOSCO
thank's PetrolGator
I am in full "plastic surgery" I think will be able to work all day long,because Paris and its region is under the snow!!! nothing worse than a Parisian in car on snow ,stay home
cheers
nicolas
cheers
nicolas
- Christian M.
Bonjour Nicolas,LE BOSCO wrote:thank's PetrolGatorI am in full "plastic surgery" I think will be able to work all day long,because Paris and its region is under the snow!!! nothing worse than a Parisian in car on snow ,stay home
cheers
nicolas
Paris sous la neige est la m�me que celle Cologne sous la neige (ici, � Cologne actuellement neige comme vous � Paris). Sur l'autoroute demain pour aller au travail qui est "dr�le" ... jam sur la route et les gens qui se surestiment et pensent qu'ils sont champion du Rallye, ou faire vous-m�me � 14 flocons de neige dans le pantalon.
Un beau dimanche
Christian
- LE BOSCO
Hello gents
yesssss!, Christian I survived to Parisian drivers!;-)
The first "modifications", are for the roof of the castle, for version as of 40-41, all this are "shaved" on the top
Below, the two "passageways" are open
the below, after adding detail
On the deck, two positioning studs are glued
Initially, I had to represent the closed hangar, and leave the bridge like that
But, after a discussed with a friend, I decided to open the hangar, which leads to his realization in full!!
The hangar
The new cuts on the deck, and the addition of a "floor"
The same, assembled
and finally, with the roof of the castle
For the moment, nothing is really finished, apply the putty, sanding, add details on bulkheads ....... still a lot of work ahead, and many difficulties for you ,for "decrypt" my threads
cheers
Nicolas
The hangar
The same, assembled
cheers
Nicolas
- LE BOSCO
Re: 1/350 RICHELIEU Dakar 1940-41
Hello all
I just finished the "mating" of the aviation hangar roof at the castle, a good " fun party " to align everything! but hey this is set
under the bridge, at the cutting of passage of the hangar,of the spacers are installed
two platforms for 37mm Double ,are installed on the front of the castle
a view of the pieces temporarily mounted
to detect of eventual defaults,a coat of primer is applied
this is all for now
cheers
Nicolas
this is all for now
cheers
Nicolas
- Rob 2
Ah Nicolas I see another masterpiece taking shape.
Rob
Rob
- dafi
As always, I can�disagree with Rob
The only one to top you is yourself!!!
Kenavo, Daniel
PS: Looking forward for the planes with working engines ...
Kenavo, Daniel
To Victory and beyond ...
- Channell
Beautiful Nicolas!
If I can accomplish half of what you do in 1/350 on my 1/200 Bismarck I'd feel like I was "the Man"!
-Jason Channell
- LE BOSCO
Thank you mates for your kind comments!it motivates me
Channell,me, I'd like to have your mastery of the 3D
Daniel I'll try to make my engines running on my Loire 130,or at least I'll try, "impossible n'est pas Fran�ais" it's very pretentious
cheers
Nicolas
cheers
Nicolas
- LE BOSCO
Hello all
this time around, I have "attacked " the barbette and the ventilation block ,This time, I redid the ventilation block from the outset, therefore, with the good number of openings,5 on the starboard side, and 7 on the front face
and nothing on the port side, and not as the trumpy piece , which be false!
all placed in its location
for the moment, all pieces redid, are "raw",without the details, they will be added later, after their making
best regards
Nicolas
best regards
Nicolas
Zetmodel
Bravo Nicolas
- mima
- L'Arsenal
Superb Nicolas!
Your work belongs to the best I've ever seen..... You are Mr. Richelieu!
Hope to see you again soon!
- LE BOSCO
Michaelmima wrote:......Hope to see you again soon! .....
I also hope
thank you zetmodel (and in good French
cheers
Nicolas
