IJN Kirishima 1942 Guadalcanal 1/700 (Fujimi)
LE BOSCO
Re: IJN Kirishima 1942 Guadalcanal 1/700 (Fujimi)
Post by LE BOSCO »
a great job, blacman :thumbs_up_1: nice effect ,I feel that it'll still be of fine workmanship!
thread to follow :wink:
cheers
Nicolas
Exquisite work and, bravo for the wood deck replacement. This kit is on my horizon, but I hate the kit deck.
Ramaja
Post by Ramaja »
Outstanding work! Can you please explain how you produce such fine photoetching for your ship? It looks like you are using Corel Draw for your drawings. How how manage to get the whole pagoda thing alligned and how you created the assonometric wiew of the structure? About the pe deck: how you manage to have a perfect match between the hull and the brass deck?
"For the one who walk in darkness with a stick is blind, but the one who sticks out in the dark is... Fluorescent!"
blacman
Post by blacman »
thank you Friends..
small udpate:
I made the imitation of plating
they are very delicate - will go under special preshading and wash - should be OK. Only thing I'm woried is that I made them quite unproperly. Though I reduced one level down from 5 into 4 intentionally - I made them a bit too low - too close to portholes.... :mad_1:
sorry - will stay that way...
Ramaja wrote:Outstanding work! Can you please explain how you produce such fine photoetching for your ship? It looks like you are using Corel Draw for your drawings. How how manage to get the whole pagoda thing alligned and how you created the assonometric wiew of the structure? About the pe deck: how you manage to have a perfect match between the hull and the brass deck?
You'a right - I'm using Corel.
Pagoda - it's just plenty of hours of designing and drawning .... :) Isometric view came from magazine - As far I remeber : Model Art No15...
Deck - as above - I took a picture of real deck and digitalized it:
...in my shipyard...
Nice.
Don't forget to drill out the rest of the portholes. Her scuttles were not sealed. Fujimi used the '44 Kongo hull for Kirishima.
blacman
Post by blacman »
:oops: - I forgot...
Thank you Dan. Will do.
blacman
Post by blacman »
portholes done. BTW - it's a shame for Fujimi to make such silly mistake.
I cut off the seals
and it was a mistake. I lost the line - and drilling later on was not straight (mentally and phycically)
I'm not quite happy with results :cry:
I'm afraid that after painting all misaligments with be bolded out.
Anyway:
PE Deck glued:
here adjustment is just perfect :cool_1:
After bad story with potholes that kind of view stimulates the imagination and gives motivation
Kongo class had beautifull design....
Holy Cow. That is amazing work.
blacman
Post by blacman »
Deck painting almost done:
I painted PE deck by mixture of white with surfacer 1000. Surfacer was intended to get rough surface:
Then school stuff came to work
they did a job like this
I make a kind of "preshading" with dark and medium brown
and finally very thin layer of deck color
then wash - and here's a deck
I like it �
I going to apply foggy layer of mat warnich and use some filters
Greetings!
Greg
hypno7
Post by hypno7 »
Hi Greg,
Your work is really amazing at every post!
blacman wrote:Surfacer was intended to get rough surface
Ha! I usually try to avoid that! I seem to get it no matter what...
blacman
Post by blacman »
thank you..
hypno7 wrote:Ha! I usually try to avoid that! I seem to get it no matter what...
yes... Surface is being used to get quite opposite results :)
But I wanted rough surface .... otherwise pencils would not get grip. And I came up with idea of using airbrush from further distance than usual to get it dry before seated. Seems worked for me :)
blacman
Post by blacman »
and this is how it looks like in daylight:
I think I' have achieved the result I wanted to get
hull is also painted and washed:
greetings
Greg
J. Soca
Post by J. Soca »
Excellent job on the deck Greg! looks almost real wood :thumbs_up_1: :thumbs_up_1:
Jose :wave_1:
Superb. This is another build thread in which I'm running out of superlatives.
blacman
Post by blacman »
thank you...
I rebuilded funnels
orignal from Fujimi:
I changed a steam pipes arragements and added rails
Steam pipes are made from brass pipe 0,3mm. For this time I made a attempt to simulate joints of pipe's segments
and funels ready:
Joe Simon
Post by Joe Simon »
Love it man!
JIM BAUMANN
Post by JIM BAUMANN »
sharp pipework :thumbs_up_1: !
:wave_1: :wave_1:
JB
Very sharp work, indeed.
ajkochev
Post by ajkochev »
Wow! Mind blowing work! Great detail! :thumbs_up_1:
blacman
Post by blacman »
Stern superstructure at the table:
stern navigation platform
windowed....
3,5m rangefinders rebuilded
Fujimi made quite nice and sharp hull but stern superstructure is very bad. Main body needs a lot of putty to make it done in any shape. Placing rangefinders on platform gives you 2 options: parallel rangefinders and chinks or no chinks and twisted RF. Attempt to level the platform - you might lose shape of surrounded supports ... :)
here is a "devil"
and placed together with second funel:
