Another 350th Scharnhorst
Re: Another 350th Scharnhorst
Unbelievable attention to detail. This is a very, very impressive build.
Rob 2
Post by Rob 2 »
Thanks everyone for your encouraging comments. :thumbs_up_1:
Rob.
Rob 2
Post by Rob 2 »
Work on the turrets has continued as well as spotting another gaff in the instructions!
The tie downs were added, made from more railings from WEM�s 700th scale set and a pair of ladders for �A� turret.
I decided the thick moulding representing the rail around �B� turret barbette had to go. I had been pondering its removal for a while but as I had already stuck the offending part to the deck and painted it I was trying to convince myself I could live with it! Nar pass me a file. While working on this and trying the turrets for fit I noticed that �B� turret was set to low, its barrels almost touching the roof of A turret. Several months have passed since I assembled the turrets but I�m certain that I followed the instructions to the letter. I would check this if you are building one of these but I think the error lies in the instructions. �A� turrets base uses part A5 while C turret uses part A9 but if you place a straight edge on a set of plans the two turrets tops should be level so why the two different base parts?. I managed to �adjust� mine by removing the base of B turret and replacing it with the spare included in the kit (I cannot confirm its part number as I had removed it from the sprue to put it in the spares box) I also sanded a mm off the base of A turret.
�B� turret suffered some damage during this which meant I had to replace some rivets with stretched sprue.
The painted turrets were added to the hull along with the stern 37mm mounts.
The SL6 gun director hoods have had some additional work done to them replacing the optics with rod and foil.
I have also been tinkering with the main superstructure adding 40swg wire over the moulded rungs and removing the moulded in ladder detail and replacing it with fine etched ladder chopped about from a Lion Roar set, a before and after picture for comparison.
I have also tided and painted the edge of the deck and added several more deck fittings including the mid-ship breakwaters.
Thanks for looking,
Rob.
jeroen zuiderduin
Post by jeroen zuiderduin »
Everything has probably already been said. I have to say that I really like your paint technique and I will bring you a military salute. It is a pleasure to watch this.
Jeroen
Rob 2
Post by Rob 2 »
Thanks Jeroen I�m glad you like what I�m doing.
Rob.
rtwpsom2
Post by rtwpsom2 »
I really like yours and Kubaro's painting techniques, but for different reasons. Being an all digital guy, myself, I like his approach to masking the scheme, it provides some very precise edges and clean appearance. But I like yours for the depth it provides.
kubaro
Post by kubaro »
oustanding work, as ever... :eyebrows:
Rob 2
Post by Rob 2 »
Thanks Gents for your comments. I also admire the clean draughtsman approach that kuba has achieved Rob, the result of a precise and ordered approach. But I do like to force the shadows and highlights and try to create contrast. I�m hoping to create the effect of a massive structure rather than a comparatively small model.
I would like your opinion on how much weathering she would have displayed. I�m aware this scheme was applied not long before her sinking so I�m planning on not much more than water streaking, what do you think?
Thanks again,
Rob.
rtwpsom2
Post by rtwpsom2 »
Well, I have said before that this isn't my realm, I was focusing on the technical side mostly so my opinion on things like coloring and weathering should hold little sway. I have voiced my opinions before and had people want to debate me on the subject but I am poorly equipped to debate such things so please take any opinion I may offer at face value as the opinion of someone not very well versed on the subject.
I know she was painted only three or four months before her demise and I know she had new sections of paint added over that some time after that, so I would assume she only had a couple of months of wear and tear showing. And most of that time she was at anchor in a sheltered harbor, so idle sailors being the devils plaything, I am sure they were not allowed to allow to much build up of grime or rust. So my best uneducated guess would be that the main deck and above to say bridge level would have been fairly clean but on the hull below the main deck and on the top sections of the superstructure might have begun to show a little rust. Harbor water being filthy I would assume the boot topping would also have been filthy. Also bear in mind when fully loaded she had a pretty low freeboard, so if you are doing a water base, you would barely see anything below the lower scuttles.
roy allen
Post by roy allen »
Niiiiiiiiiice :thumbs_up_1:
Acrylics, you just can't beat em, cracking paint job Rob. :cool_1:
As for weathering, go very lightly As Rob M said she spent most of her time in this scheme in sheltered waters.
However salt air/spray would have been constant so salt marks on hull would be visable, don't think they would have fresh water washed.
Roy
Rob 2
Post by Rob 2 »
Thanks Rob and Roy for your advice and encouragement.
Rob.
Rob 2
Post by Rob 2 »
I had some fun fitting the rail around �B� turret barbette; it took forever to get looking reasonable. I had the cunning idea, or so I thought, of not trimming the uprights from the WEM 700th scale railings I have been using for these fittings so I could glue the rail to the underside of the upper section of the barbette. That would leave a gap only as high as the thickness of the rail to hide, hmmm. :bash_2:
I fitted the platform at the back of the forward fire control room lower to allow for the height of the door and used a cut down Lion Roar etched ladder. Other than that I will let the pictures do the talking.
You will have to excuse some of the lumpy paint finish the merciless digital lens has exposed; I was forced to touch in with a brush after some overspray sneaked under my masking close to the rails on the vertical faces of the main superstructure. If I was to do this again I would paint first and add the rails later, especially now I have worked out how to do it, live and learn. I'm hoping a coat of matt varnish will help conceal things! :whistle:
Thanks for looking,
Rob.
Stefano Salesi
Post by Stefano Salesi »
this is overkilling man.
extraordinary work on your scharnhorst.
love the paint work on the deck, the camo, the p.e. work and the assembly overall.
thumbs up for you, your technique is sublime.
:worship_1: :worship_1: :worship_1: :worship_1:
Rob 2
Post by Rob 2 »
Thanks gents for the encouragement. :smallsmile:
Rob.
robertmelvin
Post by robertmelvin »
Rob, I've seen any number of Scharnhorst builds on this and other modeling forums, but I have to say that your attention to detail and the exquisite quality of your work sets your build apart! Absolutely amazing work. When you are done she's going to be a true museum piece.
Bob
Allan McBeath
Post by Allan McBeath »
I like this a lot. Nice precision work. Almost makes me think of trying something in 350 scale. but 350's just too big ;)
"The vast majority of Iraqis want to live in a peaceful, free world. And we will find these people and we will bring them to justice."
Washington DC, 27 October, 2003. President George W Bush
Kym Knight
Post by Kym Knight »
Beautiful work Rob!
Rob 2
Post by Rob 2 »
Thanks for your comments and encouragement they spur me on :thumbs_up_1: .
Rob.
Rob
Post by Rob »
This is excellent.
Rob
