These are some pictures of my current build Dragons 350th Scharnhorst. I have added extra detail from cut down White Ensign etch and made the masts from brass rod and tube.
Thanks for looking,
Rob.
I have finally started to put paint on the hull and decks. The hull has been painted in a combination of Tamiya greys including XF19, 24, 54, 63 with black and white added for high lighting and shading. The lower hull is XF9 with flat red added to lift it a little. The degaussing cable was added from Evergreen. I have tried not to get too hung on the exact shade just tried to maintain the balance between the greys, sorry to any purists reading this but after shading and the application of washes the shade alters anyway (That's my excuse and I'm sticking with it).
The deck was pre-shaded with XF64 then misted over with XF55. Individual planks were masked and XF 78 was misted over then the procedure was repeated with XF59. Everything was sealed with future and oil washes added. The swastikas are the kit decals settled in with Set and Sol. The edges were masked so they could be shaded with heavily thinned Tamiya smoke. The hull is still in its gloss coat as there will be some more washes for the superstructure before matting down. The edge of the deck will be tided and painted Grey. I had problems photographing the effect so some pictures are in natural light others used the flash.
Apart from the painting I have been adding more electrical conduits to the superstructure using the Kagero book as a guide.
The deck painting technique explained in my last post was continued onto the superstructure. The level the rangefinder is mounted on had the decking painted in by hand otherwise the technique is the same.
The ensign staff was made from brass wire sanded to a taper with mountings made from Evergreen and wine bottle foil.
The hatch on top of the range finder was made using a punch and die set, stretched sprue and scrap plastic card.
I wasn�t happy with the supplied etched ladder (See picture) so replaced it with one �borrowed� from a WEM set for the Graf Spee which has proper treads you bend to the horizontal. I�ve ordered a Lion Roar set of very similar looking inclined Japanese ladders to replace any others which happen to find their way onto this build.
I had to cut the railing into three pieces and trim approximately 1mm from each end to get a tight fit, this is becoming the norm for me when fitting Dragons own railings!
Pre shading was applied by airbrush with additional highlights using the base colour with a little white added. Some additional shading was added using heavily thinned Tamiya smoke. A very thin black oil wash has been applied and the finish will be matted down once all the weathering has been completed.
That very rare commodity called sunlight passing through the blind of my dungeon has created an interesting effect on the rangefinder control room, it is really only one shade of grey!
I have been considering what to use for the anti aircraft armament as some of the kit supplied stuff looks rather chunky and I have a WEM set �in stock� which can look a little flat and two dimensional. Dan with his build here is doing something similar with the single 20mm armament viewtopic.php?f=59&t=68145&start=140
I think all the 20mm stuff will be a hybrid of kit supplied and WEM but I think the 37mm will pass muster, the barrels are a bit overweight though. In total there are 15 pieces to each gun but there are not enough parts supplied to complete (Etch parts MA14 &15 hand-wheels) not sure why they are given different numbers as they are identical, just turn them round! Additional ones were made from wine bottle foil again (My liver will deserve an honourable mention on completion of this build) in the punch and die set and copper wire. The instructions continue to be vague requiring additional reference to work out the location of parts MA10.
C turret has been detailed including beefing up the fittings on the barbette, adding rails and replacing a seam on the cleaning rod case damaged during removal from the sprue. I thought the kit supplied turret ladders were heavy in appearance so replaced them with generic WEM ones held off the turret with stretched sprue supports.
I have also painted and fitted some more deck fittings and started detailing the other two main armament turrets.
Rob, your Scharny is looking great. Very impressive work indeed. Your PE is unbelievably clean. I couldn't come anywhere close to that quality of work. Like the way the masts turned out as well. Brass tube/rod makes a major difference. Keep up the great work and please share more pics with us soon. I've got Scharny in my stash but haven't worked up the nerve to commit to building her yet. I usually keep one large and at least one smaller project going at the same time to keep the down time to a minimum, but from all I've seen about this kit and from my experience with Dragon's DD's, I think Scharny will be a full time project when I do start her.
Bob
Very nice work on both building, and photographing those 37's.
I'm gonna have to do more work on my 20's, original barrels are just too fat.
Good idea having a guide line on turret base for your piping height.
I look forward to more updates.
