WIP: Gallery 1/350 USS Iwo Jima LHD-7
gtbred
Re: WIP: Gallery 1/350 USS Iwo Jima LHD-7
Post by gtbred »
how did i miss this? getting toooo old! good work Martin! :thumbs_up_1: :thumbs_up_1:
gtbred wrote:how did i miss this? getting toooo old! good work Martin! :thumbs_up_1: :thumbs_up_1:
You and me both!
Been very, very, very busy lately...between work, home and the newest addition to the family:
Mocha - our new Cairn terrier
The weather in the Northeast has been miserable lately, which has thwarted my painting plans. Well, that and the whole "been busy" thing. So, since I haven't had time to paint, I've been working on small sub assemblies, like the weapons.
I started building the 25mm guns, the CIWS, RAM launchers and the Sea Sparrow missile launchers. The guns (only 2 pieces) go together okay. The rest of the weapons are, frankly, a little fiddly, especially the Sea Sparrow launchers. And the fit isn't great either, but I'm pressing ahead.
Forgot my portable hard drive that has all the in progress photos on it, so those will follow, hopefully tonight!
sgtryan13
Post by sgtryan13 »
Is she gonna be ready in time for Jerseycon?
sgtryan13 wrote:Is she gonna be ready in time for Jerseycon?
Define "ready"... :big_grin:
That's a very realistic 1:1 canine model. Is it r/c?
MartinJQuinn wrote:Define "ready"... :big_grin:
Do the "as launched" before fitting out :thumbs_up_1:
Dan K wrote:That's a very realistic 1:1 canine model. Is it r/c?
It's self-propelled...
Okay...as promised, some photos.
Here are (from the Wasp instructions posted in Sean's review of that kit) the weapons I'm working on, minus the 25mm guns:
Here are some photos of the weapons being built, from a few days ago.
As I said, the parts are a little fiddly. In order of fiddliness, they are CIWS, RAM launcher and Sea Sparrow launchers. The Sea Sparrows are an 8.5 on the fiddly meter....
I'm normally not a modern ship guy, but as I said before, I'm enjoying this build, and have been intrigued by these ships since Keith Bender did his Wasp. That being said, since I don't usually do modern stuff, feel free to correct me if I get any of the nomenclature wrong...
Interesting. Are these parts crisply molded?
Dan K wrote:Are these parts crisply molded?
For the most part, yes. There is some flash on some of the parts, and the lower hull had some annoying mold lines in it.
Made some additional progress. The first set of weapons are assembled - just need some touch up and additional painting. The Sea Sparrow launchers need the most TLC.
Also found time to paint over the weekend:
With the hull (finally) painted, I was able to install the well deck and the hangar deck:
Installing the well deck
I noticed the boot stripe by the bow is a little off...but should be easy enough to fix. One goof I made: I was so eager to move ahead and glue the well deck in, that I neglected to replace the old set of finials I had been using during painting. I can work around it and get new ones in, but I just made more work for myself. D'oh!
Glad to see some progress! Hoping I can get back to the bench sometime myself!
Moving along, if ever so slowly....
See the square on the left hand side of the uppermost platform?  That is supposed to be for part A21.  Unfortunately, it's bigger then the part, so I had to remove most of it.
Not sure if the small davit hanging off the back of the uppermost platform is in the correct spot, but that is where the directions seems to place it.
Weapons for this area (minus the one gun already installed) are off to the side, awaiting some touch up, then they'll be added.
Go, Marty, go! The clock is ticking down..........
Devin
Post by Devin »
Coming along nicely.
Dan K wrote:Go, Marty, go! The clock is ticking down..........
Ahem....hello kettle. Pot here!
Additional progress made tonight...
Looking through the directions after I was done tonight, I was really struck by just how many parts there are in this kit. And that's a good thing...it's really loaded with detail.
Now the catwalks on the other side of the hull...
Lots of nice detail under the catwalks
Next couple of steps call for flipping the model upside down, to add small platforms and details to the sides of the hull:
Ran into a small issue. Parts N4 are supports that run from a platform to the side of the hull:
I thought they looked a little small compared to the other supports. I was right - they were. Looks like they didn't properly form in the mold. So, I made new ones from styrene rod:
There have been some minor fit issues and some flash, but nothing serious.
Sean Hert
Post by Sean Hert »
Also, this is a pre-production kit; this could influence as well.
Sean Hert
Return to “Completed Models”
