carr
carr
carr
DAVE V
Ukranian Slava Class Deck Colour
Hi Everyone, i have just recieved my Trumpeter 1/700 Scale Ukranian Cruiser, i have had a quick look and would like to know if the colour quoted by Trumpeter is correct, they specify Insignia Red for the deck, from the box art it appears more like Russian deck Red, of which i have White Ensign models colour. I would be grateful for any advice as to what is the correct colour.
Many thanks
Dave
Many thanks
Dave
carr
DAVE V
Many Thanks Bob, that fits with the colour i already have, only bit that i cant work out is trumpeter have made the deck colour scheme for the Vilna Ukrania, as black and russian red, all of the cruisers and battlecruisers i have seen have just the russian red deck, anyone know if that is correct or should it be just russian red.
Many Thanks
Dave
Many Thanks
Dave
carr
DAVE V
Many Thanks Bob, ill go with the Trumpeter scheme, and any how it looks pretty cool.
Many Thanks
Dave
Many Thanks
Dave
carr
Adaks
Are you referring to this structure ?carr wrote:Does anyone have any good pictures of the Kirov's propellor guards (I'm guessing that's what they are - it's the small platform type structure sticking out from the stern near the waterline)? I'm trying to distinguish whether the horizontal portion is a solid platform, mesh screen platform, or empty with just the tubular supports. None of my pictures or references have sufficient resolution to determine for sure.
If so, I think there is a mesh screen platform inside.
Sorry, I do not have any better photos
Hope it helps.
carr
There is definitely something there - this picture (bottom left) seems to imply that it was solid (solid shadow):
http://www.navsource.narod.ru/photos/02 ... 165033.jpg
Yet, I have also seen some photos in which you can see very faintly the white waterline, denoting mesh.
As to its purpose, perhaps this shot of Peter's may provide a bit of insight - safety net/platform for small boats?
http://www.navsource.narod.ru/photos/02 ... 168052.jpg
However, this shot of Peter's show that there was no mesh/solid platform (you can clearly see the shadows of the framework on the hull, with no sign of darkness between them), and is taken at around the same time as the one above, so probably whatever was there in the older ships had nothing or not on purpose to do with safety:
http://www.navsource.narod.ru/photos/02 ... 168057.jpg
carr
carr
- Cadman
- Site Admin
This is the kind of info I like to see posted here. Informative info on making the most accurate kits possible. Good work Bob.
- ozpirate
Well Bob keep the info coming. Will help me later if I decide to build it in 1/72. One question is this the same on all the ships or different to each? I plan on the Frunz / Admiral Lazarev or Pyotr Velikiy.carr wrote:For those interested in building the 1/350 Trumpeter Kirov:
Hope this helps!
Regards,Bob
Mick
Building
1/72 Admiral Kuznetsov
Mick
Tumut Australia
Mick
Tumut Australia
carr
carr
Adaks
Very good job Bob.
Your drawings are terrific � great help for all Kirov builders (I also have Trumpeter 1/350 Kirov
It is quite possible that Kirov had got identical hull with the same features.
This photo (probably Pyotr Velikiy) is showing some details of hull below the waterline:carr wrote:Also, does anyone have any photos of the Kirov's hull below the waterline to confirm what Trumpeter has presented on their 1/350 kit? Not to doubt Trumpeter's research but they've produced some pretty impressive goofs from time to time, so I'd like to verify the hull.
carr
