Calling all Oliver Hazard Perry-class FFG fans
Tony Bunch
Re: Calling all FFG Fans!
Post by Tony Bunch »
Hi Guys,
You guys want to see tough?
Hey Darren,
Now get back to the New Jersey!
Owwwwww, that's gotta hurt!
Tony
ps 3 months my boy!
Admhawk
Post by Admhawk »
Tony Bunch wrote:Hi Guys,
Hey Darren,
Tony
ps 3 months my boy!
I haven't even picked it up yet!!!! Jeez.... Maybe you could get one of your Adams finished? :heh: :whistle: :destroyer:
Darren (Admiral Hawk)
Tim Barron
Post by Tim Barron »
http://www.navy.mil/view_single.asp?id=86231
Check out the "new"platform above the removed missle launcher.
Cliffy B
Post by Cliffy B »
That's for remote controlled 25mm Bushmaster! All the ships are being fitted with at least 2 of those bad boys.
David Gatt
Post by David Gatt »
Hi Guys, I've just posted a series of photos of HMAS Sydney that I took yesterday here in Melbourne.
http://davidgatt.id.au/
David Gatt
Seasick
Post by Seasick »
Its more than remote controlled, the 25mm Bushmaster is a stabilized mount so it can stay on target while the ship sways and rolls. Its far more effective than the manually aimed version.
? Seasick?
Fletcher
Post by Fletcher »
Hi guys, I am recently back into warship modeling. :woo_hoo: My first kit is the Academy 1/350 USS Oliver Hazard Perry, any tips or tricks, or things I should be watching for with this kit?
I plan on building a full hull version, and it appears that I will have to correct the rudder, as it seems to be centered in the kit.
Thanks for the info,
Chris
Chris
Currently in the dock:
1/350 Prinz Eugen
1/350 USS Missouri
1/350 Spruance Class
1/350 HMS King George V
In the Stash:
Cutty Sark
Box Scale USS Missouri - Gift
navydavesof
Post by navydavesof »
Hey Fletcher! I am going to burst a lot of bubbles here but if you want to make it a modern Perry you will need to leave off the Mk13 launcher. The US Navy no longer has FFGs. They are all FFs; no guided missile capability. :( If you wanted to be cool about it and make a "modern" version you could build a stand over the Mk13's magazine and put a Mk38 Mod2 gun in it's center. Good luck with your build! You will find a wealth of information in these threads and with these people. I cannot wait to see progress shots.
Fletcher
Post by Fletcher »
Thanks, I will probably just build this one straight out of the box, except for correcting the rudder position. Once I get my skills back, I may choose to do some modifications to future kits.
Can anybody tell me how far the rudder is to be offset from Center?
Chris
Chris
1/350 Prinz Eugen
1/350 USS Missouri
In the Stash:
Cutty Sark
Cliffy B
Post by Cliffy B »
The kit is a bit of an amalgam of several Perrys. It comes with both long and short hull stern/flight deck pieces but only decals for the Perry (a short hull) and only an SH-60 (only on the long hulls). Instructions tell you to build a short hull and put the SH-60 on it which is wrong. The short hulls only carried SH-2 Sea Sprites and never got RAST. ONLY the ships with RAST, the long hulls, carried SH-60s. If you know what to look for you can find the appropriate parts and build either version but you'll need to get some aftermarket SH-2s and/or more decals. WEM makes the helos and Iron Shipwright's makes the decals. If you need help figuring out which parts to use for which version let me know and I can give you part numbers. Feel free to keep asking questions as well man, can't wait to see your FFG!
-Mike
Fletcher
Post by Fletcher »
Thanks Cliffy B, I will remember that....I considered either building it as the Oliver Hazard Perry, with the short hull and finding the right choppers, or as the USS Ford, with the long hull and using the SH60s. Are the decals still available that are shown a few pages back?
I'm going after putty tommorrow, and some more glue....maybe even paint....then the hull should be coming along
Chris
Chris
1/350 Prinz Eugen
1/350 USS Missouri
In the Stash:
Cutty Sark
Sean Hert
Post by Sean Hert »
Cliffy B wrote:That's for remote controlled 25mm Bushmaster! All the ships are being fitted with at least 2 of those bad boys.
Should make it a remote controlled Mk96... or a navalised M151 RWS.
Sean Hert
Fletcher
Post by Fletcher »
Does anyone make a model of the MK38 Mod 2? Where would I find dims on the platform that holds it?
Chris
Chris
1/350 Prinz Eugen
1/350 USS Missouri
In the Stash:
Cutty Sark
Cliffy B
Post by Cliffy B »
Veteran Models makes the Mk-38 Mod 1 (crew served version) in 1/350. If you want to make the remote controlled version you'll have to scratch one out of the Mod 1. Same for the platform over the old Mk-13.
Look around at photos of the FFGs on Navy Newsstand for high-res closeups. They'll be you're best bet. Search for the Mk-38 as well.
http://www.navy.mil/view_photos_top.asp
Good luck!
Fletcher
Post by Fletcher »
Well I decided to go with the origional verion of the ship, and also to build the OHP herself. I will order the correct helos from WEM and keep the SH60s for other projects.
Right now I have the hull assembled with the deck on it, and the main superstructure is assembled. So it's time for paint.
I am really impressed with the Academy kit, so far everything has gone together perfectly!!!
Chris
Chris
1/350 Prinz Eugen
1/350 USS Missouri
In the Stash:
Cutty Sark
Dave from Downunder
Post by Dave from Downunder »
Hi
Just started my Academy kit as well. Have the PE from White Ensign Mine is a long hull. and as its a 2002 build still a FFG. What this about the rudder not right - can anyone tell me were it should be before i set it in. (that was to be tonights job)
What errors are there on these kits - I notive th eWhite Ensign has two different boat decks to be used - which one of a long hull (Jarrett) in 2002. I've been trawling teh web for photos to aid in teh build.
Dave
1/350 Slipway:
USS John C Stennis
Stennis CBG 2002:
Operational:
CG73 USS Port Royal
DDG73 USS Decatur
CG57 USS Lake Champlain
FFG33 USS Jarrett
Planned
DD967 USS Elliott
USS Salt Lake City (SSN-716)
USS Jefferson City (SSN-759
Fletcher
Post by Fletcher »
Dave,
In the kit the rudder is centered in the ship, however; from everything I have read, it should be offset 18" to the Starboard side.
Chris
Chris
1/350 Prinz Eugen
1/350 USS Missouri
In the Stash:
Cutty Sark
Look about halfway down on this page.
Tracy, it's also in this thread on page 8 :P
viewtopic.php?f=49&t=21745&start=140 (bottom of page)
Cliffy B
Post by Cliffy B »
Anyone know why the rudder is offset? Is it due to the torque of having only one screw?
