Calling all RM Littorio-class fans!
Re: Calling all RM Vittorio Veneto-class fans!
Is the waterline plate really that important? Can't you just make one out of a sheet of 0.5mm styrene?
Atma
Post by Atma »
Im not able to do that, my skill is low, can you mail me one ?
J/K :big_grin:
Atma
Post by Atma »
One more comment on the RM Vittorio Veneto and RM Littorio in 1/700 release by Trumpeter/Pit-Road. Why the hull it doesn't have the boat davits in folded position(or in normal position as a separate part) like in the RN Roma's hull ?
Also now comparing the 3 ships, I can see clear that the RM Roma's hull is far better looking that the RM Vittorio Veneto and RM Littorio.
mermaid
Post by mermaid »
Hi! Could you post an image side by side to compare? Thanks!
Atma
Post by Atma »
That joke isn't funny anymore, the 155 mm secondary barrels are so fragile ! Anyone can recomend me a brass barrel replacement ?
Thanks in advance.
mermaid
Post by mermaid »
Atma wrote:Also now comparing the 3 ships, I can see clear that the RM Roma's hull is far better looking that the RM Vittorio Veneto and RM Littorio.
Dear Atma
Could you post a picture to see and compare? Thanks!
Atma
Post by Atma »
I havent forget your request dont worry :wave_1:
I just need to find/or get my camera to work.
Giampiero
Regia Marina
Regia Marina
Post by Giampiero »
Atma wrote:That joke isn't funny anymore, the 155 mm secondary barrels are so fragile ! Anyone can recomend me a brass barrel replacement ?
Thanks in advance.
Hello
in our catalog set AF078 set barrels for kit Roma - Littorio - Veneto Trumpeter 1/700 (152 mm) x12
:wave_1:
Giampiero
Regi Marina
Atma
Post by Atma »
Thank you !
Atma
Post by Atma »
Quick question, both RM Littorio and Vittorio Veneto in 1/700 by Trumpeter/Pit-Road come with 13 double 20mm AA guns, is that correct ?
I always though that the 1943 RM Roma had larger numbers of small AA guns than RM Littorio and Vittorio Veneto's 1940/1941 configuration.
Thanks in advance.
Secondo
Post by Secondo »
Atma wrote:Quick question, both RM Littorio and Vittorio Veneto in 1/700 by Trumpeter/Pit-Road come with 13 double 20mm AA guns, is that correct ?
Thanks in advance.
As both Littorio and Vittorio Veneto were torpedoed many times, they didn't lack time to get retrofitted with a more powerful suite of light AA, while Roma got his own increased while still being fitted out. Both the first two ships originally had only 8 20 mm twin mounts; in 1942, Littorio received 6 new mounts, equalling Roma's 14, and Vittorio Veneto had 8, thus detaining the record for the most heavily armed ship of the class.
Atma
Post by Atma »
So, Im a bit confused.
Trumpeter's RM Vittorio Veneto(and RM Littorio) in 1/700 has 13 double 20mm, 4 single 37mm and 8 double 37 mm AA guns.
Trumpeter's RM Vittorio Veneto is a 1940 mode(and RM Littorio is a 1941 mode).
Is that AA suit correct for a 1940 mod(and 1941 mode for Littorio) ?
Thanks in advance.
Secondo
Post by Secondo »
Atma wrote:So, Im a bit confused.
Thanks in advance.
Well, from 1940 till 1942 both ships only had 8 20 mm twin mounts; at least the number of 37 mm guns is right.
By the way, all guns were always embarked in pairs, so it wouldn't be correct to have 13 mounts in any case.
Atma
Post by Atma »
Well then the Trumpeter's RM Littorio and RM Vittorio Veneto has a wrong number of double 20mm AA. Littorio is stated for a 1941 version and Vittorio Veneto for a 1940 version.
Can you point me the locations of the AA suit of RM Vittorio Veneto's AA gun in 1940 ?
Thanks in advance.
Trumpeter's RM Littorio light AA guns for a 1941 RM Littorio is 13 double 20 mm 4 single 37 mm (in the bow) and 8 double 37 mm. Same for the 1940 RM Vittorio Veneto, wich I guess is wrong ?
Atma
Post by Atma »
Okay I studing the instuction of RN Vittorio Veneto, Italian Battleship, Regia Marina 1:700 Scale.
Trumpeter's RM Vittorio Veneto label the battleship as a 1940 version, but accordig to the Regia Marina's kit, the RM Vittorio Veneto didnt had on her forward 152 mm secondary guns double 20mm AA guns picture from the Trumpeter's instructions:
Neither on the number 3 main turret:
Also those:
Shall I not use those double 20mm AA guns for a 1940 version of RM Vittorio Veneto ?
Thanks in advance.
Giampiero
Regia Marina
Regia Marina
Post by Giampiero »
Ciao,
I send you today , a diagram of the disposition weapons Veneto class battleships today
Ciao
Giampiero
Atma
Post by Atma »
Thank you, waiting for the diagram !
Secondo
Post by Secondo »
I can tell you for sure that the mounts on the bandstands on the fore 152 mm turrets and those near the aft main turret barbette were not there until 1942. Neither were there the two mounts on the boat deck: they were on the main deck below, instead; so yes, you spotted the right guns that shouldn't be there :thumbs_up_1:
Atma
Post by Atma »
So Trumpeter mixed up the 20 mm AA guns as both ship are from 1940 (RM Vittorio Veneto) and (RM Littorio)1941.
By the way, this gun was present on a 1940 RM Vittorio Veneto ?
Thanks in advance :big_grin:
Secondo
Post by Secondo »
Yes, it was; there should be another one in its same position, starboard side. Of course, no boat was carried on the main deck, as to not impair the firing sector of the guns.
