Calling all IJN Fuso (扶桑) and Yamashiro (山城) fans
mermaid
Re: Calling all IJN Fuso & Yamashiro fans
Post by mermaid »
I wonder if they installed an anti-blast bulwark there, peculiarly only on one side, when they did it and why removed and when? Is there any record of it anywhere? In Sculsky's book perhaps?
Atma
Post by Atma »
This is not an anti-blast measure, is extra living quarters according to Januzs Skulsky's book, "Anatomy if IJN battleship Fuso".
Added after the last major reconstruction and later removed during the last AA refit late 1943 or early 1944 for weight saving measures. Aoshima's 1/700 IJN Fuso has it but you need to remove it if you make a 1944 version. Hard to do that in 1/700.
Is interest to note that some Japanese sources dosent even show that extra living quarters and even the official drawings from the shipyard of Kure.
Atma
Post by Atma »
The extra/new pars on the upcoming 1942 IJN Yamashiro by Aoshima:
As you can see, its not a completely new tooling. Just the parts pictured are retooled.
Atma
Post by Atma »
While here you can see pictures of the new tooled IJN Yamashiro in 1942 and 1944 mode and IJN Fuso in 1942 and 1944 mode by Fujimi in 1/700, out in mid June:
http://www.fujimimokei.com/prod_syosai/ ... _fuso.html
Atma
Post by Atma »
Oh and there will be two dedicated PE sets for both versions and that means for the 1941 and 1944 for both IJN Fuso and IJN Yamashiro.
A good test shot preview of the new Fujimi 1/700 Yamashiro sprues: http://mokehana.blog34.fc2.com/blog-entry-357.html
Atma
Post by Atma »
Notice that it has the correct IJN Yamashiro's turrets tops for the first time in 1/700 and in plastic. Also notice how nice the detail is at the aft superstructure.
redoctober27
Post by redoctober27 »
It looks so good!!!!!! :woo_hoo:
Atma
Post by Atma »
And finally the IJN Fuso 1941 mode is released by Fujimi in 1/700, 1944 version and IJN Yamashiro in 1941 and 1944 will follow:
http://www.1999.co.jp/eng/10182386
Also a PE set:http://www.1999.co.jp/eng/10184500
and a wooden deck:http://www.1999.co.jp/eng/10184502
is also released for IJN Fuso in 1/700 by Fujimi.
As you can see for the first time in /700 we have the correct details around the funnel, aft bridge, deck and Pagoda and of course all those goodies will be present in IJN Yamashiro too including correct turret tops.
Atma
Post by Atma »
And the 1944 version of IJN Fuso is also out, enjoy :thumbs_up_1:
http://www.1999.co.jp/eng/10182387
Atma
Post by Atma »
Finally the NEW molded IJN Yamashiro 1941 from Fujimi is out:
http://www.1999.co.jp/eng/10184507
At last we got an accurate INN Yamashiro, and soon a 1944 version is also out.
Atma wrote:Finally the NEW molded IJN Yamashiro 1941 from Fujimi is out:
Since I have the Aoshima 1944 in the stash and no inclination to swap it for the Fujimi version (since I have PE and a wooden deck for it), what are the most glaring issues with the Aoshima release vs. the Fujimi release?
Atma
Post by Atma »
First of all wrong stern planking, wrong turret tops, inaccurate funnel base and the tripod in the pagoda was oversimplistic and many deck items are just copied from IJN Fuso(both kits on Aoshima release use same deck parts). Plus some inaccurate rangefinders on the pagoda.
As you can see from this post, Aoshima is also trying to correct those mistake in the 1942 IJN Yamashiro retake version, that is out in August. Still rangefinders and turret tops are wrong. And the various supports of the Pagoda is better molded on Fujimi release.
Atma wrote:The extra/new pars on the upcoming 1942 IJN Yamashiro by Aoshima:
Atma
Post by Atma »
Forgot to add, that the new retake version of Aoshima is very peculiar cause it has an obvious mistake, it has on the deck(at the bow) the third extra anchor and is totally wrong, that anchor and any item on the deck related to that anchor was removed after the last major reconstruction in mid-late 1930's.
Atma
Post by Atma »
The new molded 1/700 IJN Yamashiro 1944 by Fujimi is out:
http://www.1999.co.jp/eng/10184508
Notice also that Fujimi offers also single and double 13mm AA guns for the 1944 version.
Enjoy :thumbs_up_1:
redoctober27
Thank you for the wonderful new Atma!!! :thumbs_up_1:
denstore
Post by denstore »
Nothing new in 1/350?
/Magnus
Atma
Post by Atma »
We already have a 1/350 IJN Fuso and IJN Yamashiro by Fujimi.
Philip LaVoie
Post by Philip LaVoie »
I just scored a 1/350 Fuso on eBay, so now I am putting a list of aftermarket parts together for the built. It looks like the Fujimi PE set for the Fuso is no longer available, does anyone know when or if the 1/350 WEM Fuso set will be released? I see it was announced more than a year ago.
Also, I guess I need a wood deck and maybe a barrel set. Any other suggestions for after market parts?
- Thanks!
Update:
Well, I think I have it covered. Found a store with the Fujimi PE in stock, ordered a set of Veteran models type 89 dual purpose guns and searchlights, wood deck, barrel set and Fuso Ship Anatomy book. I think that will cover the build, now I just need to find a place to display it when I finish.
For those with the Fujimi 1/700 Yamashiro 1944 Kit #s 72/431123, there's a slight error in the instructions:
The callout for Y3 should instead be for Y4.
