proflooney
oh well thanks anyways dunno what problem is must be something with connection of qmail
bigjimslade
Still tryingproflooney wrote:oh well thanks anyways dunno what problem is must be something with connection of qmail
proflooney
dunno why its not letting you send email to me do you have ftp? let me pvt msg you my ftp info
- Gernot
That mail error is clearly a SSLv3 error. Since SSLv3 is by default disabled these days, if either the client or the server still has only SSLv3 capability (and not TLSv1 or above) while the other refuses to use anything less than TLSv1, then communication simply is not going to happen.
I don't know the odd mail domain you are replying to, but it is quite likely that the administrators have not been diligent and have an old version of openssl running on their mail server, or else neglected to update the SSL/TLS versions permitted (and probably did not set up the list of permitted ciphers and their order of precedence either).
If that is the case (and not on the mail client on the sender's side), then the people on the mail domain are going to receive fewer and fewer messages!
Gernot Hassenpflug
proflooney
yea i know its not on my end i am using mediacom and have no problems wife works there and they are constantly updating and upgrading to keep current plus it is one of the largest cable and internet providers
- Gernot
Then it must be the qmail program that does not understand the latest TLS version that your mail domain is accepting. Usually qmail then falls back to some set version of SSL, and tries again (second connect attempt). The error then masks the error of the first connect attempt. I surmise qmail on the sender's side has an older version of curl/openssl which does not understand TLS1.2 (which I assume perhaps is the only version permitted on that mail domain).
Gernot Hassenpflug
proflooney
it came through that time
proflooney
so Looking at a glance if I read correctly there are 344 frames which puts them at 30.95058139534884" apart I was taught ship frames are evenly spaced
Ok I see row 2 is the waterlines what is Column B? the rest I pretty Much understand on Frames sheet
proflooney
Ok Jim So Now I will take those dimensions and insert them into my template excel sheet so that the feet inches and 8th inch are in seperate cells then goes onto the second sheet I will creat to which they are all converted then to the 3rd sheet ill create which will create tables from them for importing into cad to draw the frames. will take a while and lot more stuff missing but it is a start for the hull.
thanks a lot I appreciate the file it will give me a good start til I can find the rest of the data like for the bow curve the transom the keel etc
bigjimslade
The Iowa frames are spaced every four feet. However, some places have fractional frames placed at 1 and 2 feet. Some locations only give the 1/2 frame dimensions.
- Admhawk
According to this post, stations are equally spaced, not frames, which corresponds with my experience.proflooney wrote:so Looking at a glance if I read correctly there are 344 frames which puts them at 30.95058139534884" apart I was taught ship frames are evenly spaced
viewtopic.php?f=13&t=156889#p698231
Darren (Admiral Hawk)
proflooney
yea i was meaning stations I forgot ships have frames and stations not really sure what the frames things are but I was meaning the stations
- BB62vet
CliffyB,
On a totally different topic, can you possibly enlighten us as to when, and why the sliding padeye replenishment unit was installed on WISCONSIN? This is unique among the four IOWA class and one of our forum members brought this up over on World Affairs Board Forum. I (first) found the photo below by Googling it and then saw it on your Photobucket album (May 2007 #7): I know this photo doesn't show it that well, but it's the only one I've got!
- Cliffy B
Best I can tell from photos is that she got it prior to leaving for the Gulf. Photos I have from 1988-89 do not show it but photos from 1990-1991 in theater and afterwards show the padeye. If I remember correctly its another one of those small features that makes Wisky unique from her other sisters.
- BB62vet
Thanks CliffyB for the pad eye response. Once again proves that the 4 are and always have been individual ships!
anj4de
Hello all
Today I received my first ever Shapeways parts...1/700 New Jersey round bridge! Here are some pictures of the real parts, we do not get to see those in the flesh all to often and Shapeways only shows "artist impressions". A spezial thanks to Steve (Model Monkey) for making those. The detail is breath taking...and my 1980ties rebuild 1/350 Missouri will get changed into a New Jersey soon as well!
cheers
Uwe
PS: Next to the now New Jersey, that once was Iowa, is my Wisconsin 2019 in the stage of having her new VLS installed...
cheers
Uwe
Thomas E. Johnson
Is there any information available as to the physical appearance or state of weathering / color fading that the Missouri was in, during the summer of 1945?
bigjimslade
DISCONE Antenna Measurements
Does anyone have measurements for the DISCONE antenna on the Iowas. In particular, I am looking for measurements of the base. Tube diameters, height, etc. I have some information for the actual antenna.
thanks.
thanks.
Thomas E. Johnson
Re: DISCONE Antenna Measurements
On a completely different note, and this is something that I have always been confused about. What purpose does this antenna serve? I know the New Jersey had it during Vietnam, and it was added to the other three ships in the 1980s.bigjimslade wrote:Does anyone have measurements for the DISCONE antenna on the Iowas. In particular, I am looking for measurements of the base. Tube diameters, height, etc. I have some information for the actual antenna.
thanks.
Came across the following page when googling "Discone antenna iowa class" - half way down there are high-resolution photos of the blueprints for the antenna, including with clearly legible dimensions: http://www.virhistory.com/navy/ant-ship.htmbigjimslade wrote:Does anyone have measurements for the DISCONE antenna on the Iowas. In particular, I am looking for measurements of the base. Tube diameters, height, etc. I have some information for the actual antenna.
thanks.
Apologies if that's the one you already have.
