1/350 french battleship RICHELIEU/l'Arsenal Upgrade Set
Dave Rowe
Re: 1/350 french battleship RICHELIEU/l'Arsenal Upgrade Set
Post by Dave Rowe »
Beautiful work Nicolas :thumbs_up_1:
Jean-Paul Binot
Post by Jean-Paul Binot »
Considering the dog that the original Trumpeter kit happens to be, Nicolas's build is nothing short of magnificent. In detail and 'cleanliness', it rivals much larger models. :thumbs_up_1:
Jean-Paul Binot
LE BOSCO
Post by LE BOSCO »
thank you guys :thumbs for your kind appreciations :thumbs_up_1:
Jean-Paul a special thank you for your appreciation,indeed, the beginning of my documentation ,were the pictures of Richelieu (of the "mus�e de la marine" ) that you had put online.......they helped me a lot :thumbs_up_1: :thumbs_up_1:
cheers
Nicolas
Kometa
Post by Kometa »
:woo_hoo:
:woo_hoo:
Spectacular. Incredible.
How beautiful is the Richelieu!
:thumbs_up_1:
On workbench:
Uss Fletcher DDG-992 1/350
Uss Lexington 1/700
and more, more, more
My Galery:
Instagram: Tamboshipsmodels
Christian M.
Post by Christian M. »
Wow! Congratulation to that awsome build again ... a clean, super built and painted model! :thumbs_up_1:
navydavesof
Post by navydavesof »
This is quite the inspirational ship. Wonderful work. With the stock of new pieces you have produced, are you going to build more RICHELIEUs? It would be a real treat if you were to tackle the Alsace class battleship.
Congratulations on completion. It is very impressive! I look forward to your next project, and I hope you let us follow your progression on this website.
tko24
Post by tko24 »
This is a beautiful build! It really makes me wish that Trumpeter would have also released the JEAN BART in her 50's fit in 1/350 like they did in 1/700. I have this kit with all the upgrades but I haven't started it yet. I wonder how hard it would be to convert one as Jean Bart. The secondary armament would probably be the hardest part of a conversion. Great work! :thumbs_up_1:
JIM BAUMANN
Post by JIM BAUMANN »
That looks just great!!! :thumbs_up_1:
sharp as a blade....!!! :thumbs_up_1: :thumbs_up_1:
see you at Telford 2013 for a Gold Medal..... :wave_1:
Best wishes
JB
Channell
Post by Channell »
Incredible job Nicholas! Like others have mentioned that was a mediocre kit out-of-the-box at best but you remade it into something truly extraordinarily. People are gonna feel robbed if they look at your finished boat before they open the box on their Richelieu. :big_grin:
-Jason Channell
LE BOSCO
Post by LE BOSCO »
gentlemens
thank's for the welcome given to my Richelieu :wave_1:
to meet
Jim ,with this one(version 52), for Telford,it is not possible :huh: but ,with the "news" Richelieu version 1940 no problems :smallsmile:
navydavesof
it responds in part to your question :smallsmile: and of course, I sharing on this forum,for the "Alsace", it is not in my agenda,but, Why not one day
tko24
for the Jean Bart ,indeed, the secondary armament would probably be the hardest part for a conversion,but with a little time,nothing is insurmountable :smallsmile: I'm not saying " never "
I draw your attention,on my pics ,the turrets are reversed!!the turret with the bathtubs for the 20mm ,not going on the first "barbette", but on the second (a bit of precipitation for share with you)
thanks you again for your kind comments
best regards
Nicolas
Rob 2
Post by Rob 2 »
Beautiful work Nicolas.
Rob.
J. Aguilar
Post by J. Aguilar »
great job Nicolas, looks awesome.
How's your Type VII/C 41?
best regards
JAM
LE BOSCO
Post by LE BOSCO »
Hello gent's
thanks for you comments :thumbs_up_1: Jam the VIIC/41is in dry dock,but ,the shipyard re-started again one day :smallsmile:
I just finished a "small session" that I dreaded slightly, namely laying the name RICHELIEU
indeed my friend Bruno was engraved at my request the "baptismal name"
I had no idea how to implement it all in .. (hence my apprehension :smallsmile: ). and after much thought, I found a walk to follow
initially after detaching the letters one by one from their support
I'm stuck on a support (blue tape) and I painted white a aerograph
Then on another support I glued the letters Upside Down
I sprayed and spray glue (for the designer)
I had previously superimposed several thicknesses of masking tape, cut into thin strip, and I have served as a reference for the "feet" of letters
I finally affixed the letters one by one
Repositionable glue helping any alterations in their
once removed the tape, I applied micro drops of cyano extra fluid and that was it ......!
Here are the result
Then, davits with whaling 8 m were put on a final basis
I remind you that this configuration is specific to the "model 52", not to install a previous version!
and finally, Hawse side were painted black, the middle too, but having received this "protuberance" for a correct positioning of the anchor on the hawse
giving it a small side Mick Jagger to my Richelieu :big_grin:
cheers
Nicolas
Jean-Paul Binot
Interesting, but why did you not just use a stretch of cello tape to hold the letters together ? Assuming that Bruno had provided the proper spacing between the letters (as it seems to be the case), it was a pity to cancel this advantage by detaching them one by one and having to recreate the same in a elaborate way as you did. A stretch of cello tape over the letters, cut the entire block loose from the fret, trim each letter while still attached to the tape, spray some glue at the back of the letters, use another tape to provide the alignment on the hull, et voil� !
I do not mean this as a criticism at all, and maybe you tried what I suggest and it did not work, but maybe you did not think of this at all, in which case it may come handy for the second Richelieu ?
Jean-Paul Binot
gtbred
Post by gtbred »
LE BOSCO
Post by LE BOSCO »
Hello Jean-Paul
This is not the spacing,that I dreaded,but ,avoid that something be glued on the letters, indeed,as I used the ZAP extra thin,there was a risk that the cello tape ,remains glued.
the use of "spray mount",brings a flexible of implementation. I'm not saying that your solution is bad,but I had more "feeling" with mine and I think I'll keep it for the second
friendships
Nicolas
sirpaul
Post by sirpaul »
Nicolas, That is some beautiful work. It seems that you have missed nothing. Your deck looks great and has a glow that keeps pulling my eyes towards it. Bravo! :wave_1:
Paul
On the Bench
1/350 Independence
1/350 Dunkerque
1/350 Shimakaze
1/350 Sharnhorst Dragon
1/350 Belfast
moomoon
Post by moomoon »
Belle b�te! / very, very nice! :thumbs_up_1:
dafi
Post by dafi »
Lovely details as usual! Superbe!
As I was struggeling with my lettering too, it is a great idea to use the SprayMount as positioning help! It was good to ad some extra fixing like the CA, as SprayMount can loose grip with time or heat (sun!)
As the CA sometimes build up to much, some colorless paint/varnish is also good for the final fixing.
Kenavo, comme disent les bretons, Daniel
To Victory and beyond ...
LE BOSCO
Post by LE BOSCO »
Thank you guys
I thought I had finished with the parts to do! not ! I just forgot the stern anchor (ancre de d�troit in French)
trompy them, they have been doing it
I just seem to see a pair of donkey's ears or bunny's of playboy :big_grin:
besides being false of form,they are out scales!!
I therefore again an anchor from scratch
the same with the "arm" installed
and as usual comparison with the piece of 1cts and that of Trumpy
we realizes well the oversizing!
and finally a photo (rotten) of the anchor (without arm) to the post
I can tell you that I will try to duplicate it in resin, because it is a real headache has realized (5h00)
best regards
Nicolas
