I your propose the step by step mounting of the battleship Richelieu in the fifties (52)
the model it is that of Trumpeter, with all the errors
but I will try to remove these errors
the first stage will be mounting the hull,as the model will be presented on a base , the model it is "full hull"
the stern with the brackets and shafts
the bollards and fairleads will be removed because they are ""ugly"" (see thumbnail)
I'll redo them in resin,the master's
there will be work on the model!!!!
see you latter!
Nicolas
