Calling all SMS König class fans
Very nice work!! Please keep the updates coming.
masch3
Post by masch3 »
@ Draze: True inspiration, what you are doing there!
** lurking after abandoning all projects **
Yevgeniy
Post by Yevgeniy »
Drazen,
Thanks for the answer. I should have guessed it myself - as usual the most brilliant ideas are the simplest.
Good luck.
Yevgeniy
Francisco P. de Nanclares
Post by Francisco P. de Nanclares »
Impressive stuff, Drazen!. Wow!. Looking forward to seeing more of this upcoming marvel. :thumbs_up_1:
Cheers.
Pachi.
Image I will miss you Werner. Fair winds and following seas.
Laurent
Post by Laurent »
Indeed , impressive stuff ! :thumbs_up_1:
Regards ,
Laurent
Avery Boyer
Post by Avery Boyer »
Absolutely fantastic work :thumbs_up_1: :thumbs_up_1:
Jefgte
Post by Jefgte »
Very nice model.
Congrats for the clean work.
Jef :wave_1:
Current 1/700 WL
HMS Repulse
masch3
Post by masch3 »
I just wanted to say that I edited my answer on colours on page 2. :wave_1:
ingura
Post by ingura »
Drazen
Post by Drazen »
Hello again!
First, I want to thank you all for your kind words and comments. :thanks:
@Ingura - thank you for your remark and photos, you are not nitpicking! These photos are indeed interesting, I don�t have them in references I�m using for my K�nig build. Will correct those torpedo doors, it�s not too late and does not require too much extra work.
Meanwhile, here are the pics from yesterday. The torpedo net booms are fabricated from 0.8 mm medical needles. I decided to discard the ICM�s because they are too short (see below), and make my own ones.
Boat davits are also glued in their positions. I drilled and shaped a hawsepipe for the stern anchor in the center rear of the hull, so it lines up properly with the molded hawsepipe in the aft deck. Very carefully I managed to drill an eyelet on the anchor for attaching the chain.
Nameplates were also added on upper hull sides.
Cheers!
:D :D
ingura
Post by ingura »
ingura
Post by ingura »
Drazen
Post by Drazen »
Nice and useful pics, thanks again. Although K�nig had no stern tube - one bow, two mounted on each side - that photo is particularly interesting.
She is going to be in her pre-Jutland fit, so no liferafts for this baby! :D :D Nevertheless I am curious - what is the correct colour for liferafts on German warships, if not yellow?
ingura
Post by ingura »
Guido
Post by Guido »
Hi, Peter!
I wonder: Does that rule apply for the textile part of the float, too? ...or would that be canvass-colour?
TIA
Guido
AKA "Tailor"
VMF'06 - German Gamblers
Hanchang Kuo
Air identification markings
Post by Hanchang Kuo »
Quick question...Did they carry white circle air identification markings on turret tops at Jutland?
UN-altered REPRODUCTION and DISSEMINATION of this IMPORTANT Information is ENCOURAGED, ESPECIALLY to COMPUTER BULLETIN BOARDS.
chuck
Re: Calling all Konig-class (Imperial German Navy) fans!
Post by chuck »
How did you make the brass eyebrows for the scuttles?
Drazen
Re: Air identification markings
Post by Drazen »
Hanchang Kuo wrote:Quick question...Did they carry white circle air identification markings on turret tops at Jutland?
Well, I don�t really know. There is no photographic evidence to confirm that. On the other hand, there is a photo of battlecruiser Seydlitz steaming home after the battle which clearly shows distinctive white circle painted on top of her forward 280 mm turret, so what bothers me is - can this be appliable for uppermost turrets forward and aft on ALL German capital ships during this battle, too...? :anyone:
chuck wrote:How did you make the brass eyebrows for the scuttles?
I used horizontal bars from 1/700 railings.
They were surplus pieces; the rest of the railings I used to make funnel rings. They were cut to correct length and 1.5 mm drill was used to bend them to shape
Steve Jones
Post by Steve Jones »
Hi yevgeniy,
if you want to really go to town on your dreadnoughts, try having some of the hatches on the skylights open (only in harbour of course!). they would have had a glass hatch underneath which could also be opened for fresh air.
regards
Steve
That's a brilliant idea!
