1/350 french battleship RICHELIEU/l'Arsenal Upgrade Set
LE BOSCO
Re: 1/350 french battleship RICHELIEU/l'Arsenal Upgrade Set
Post by LE BOSCO »
denstore wrote:....You should consider casting a few extras of the resin parts to sell as an update set. ......
Hello Denstore
This is "of garage kit",with all that entails this type of production :smallsmile: it's for my use personal, I am far from the sales approach :smallsmile:
thank you for your feedback
best regards
Nicolas
LE BOSCO
Post by LE BOSCO »
Hi gents
After the holidays, resumption of work in my shipyard!!
I decided to install the docking keels which are not present on the hull. I cut keels from the plastic card of 2.5mm of thickness,having drawn the place of the keels on the hull,I stuck them
She are then sanded has flat on some sandpaper
Obtaining this result,more thick towards the bow and the stern (arrows),and amidship very fine
the final result
I not going to make all the intakes of water under the hull!
Then, the superstructure of the turret of the rangefinder of 380 is detailled whit PE doors,plastic card,and one of my resin parts
The turret is detailled ,and one news bathtub is instaled on the top
The new optics of rangefinder
the new mast of aerial
And to finish,the master of the air intake
All the temporarily installed parts
see you latter
best regard
Nicolas
Dave Rowe
Post by Dave Rowe »
This is brilliant work Nicolas :thumbs_up_1:
LE BOSCO
Post by LE BOSCO »
HI Dave
Thank you for your comment!your project of Arromanche (and Karel Dorma),has which level of progress is he ? Mine is for the moment has the stop, the fault has a lack of documentations on passageways !!What is funny, it is you that made, two projects ( T2 and Furtive frigate )that I would like to try to realize In one of my "eight lives" :smallsmile:
best regards
Nicolas
Dave Rowe
Post by Dave Rowe »
Hi Nicolas
My Karel Doorman build has temporarily stopped for the same sort of reasons, lack of details on those passageways! I may have to portray something that might be suitable rather than completely accurate.
I know what you mean, so many kits so little time :big_grin: (something I would never admit to my wife :heh: )
Best wishes
Dave.
Christian Bruer
Post by Christian Bruer »
Hello Nicolas,
I follow your VIIc boat from time to time and was really impressed by all the details you add to the scale 1/72 model.
I did not noticed you start a scale 1/350 Richelieu. Well I have taken a closer look to all the extra work and I was really impressed by all the fine and clean work you have made. Nice to see you try to add even small details like the air intake and the rangefinder.
One question, like me you work with styrene, what kind of glue do your use?
TIA
Christian
AKA "Painter"
VMF'06 - German Gamblers
LE BOSCO
Post by LE BOSCO »
Christian Bruer wrote:One question, like me you work with styrene, what kind of glue do your use?
TIA
Thank you Christian for your comment!! I use TAMIYA glue extra thin or MR.CEMENT glue also extra thin !for me,the best glues ! before, I have used the Trichloroethylene....efficient !but too bad for my neurons :rolf_3:
regards
Nicolas
JIM BAUMANN
Post by JIM BAUMANN »
good work!
Certainly good attention to often forgotten detail! :thumbs_up_1: :thumbs_up_1:
JIM B
LE BOSCO
Post by LE BOSCO »
Hello Jim
thank you for your appreciation,It is true that in this reference, Trump has forgotten many details and made unforgivable mistakes,but this has the advantage of allowing me "to have fun" on this model!!
amiti�s
Nicolas
LE BOSCO
Post by LE BOSCO »
Hello gents
I continue in my "Correction work" on the turrets of 380 ,I attack the blast bags
The "genuine" Parts
The first tests,starting from one of my resin parts
the turret with four new blast bags and the brass guns fron l'arsenal
six new blast bags waiting molding (With different folds)
I also made the chimneys of expension
And also a new air intake (Present in three copies in front of the turret A)
The next stage will concern the crane
best regards
Nicolas
Christian Bruer
Hi Nicolas,
different blast bags - great idea! Just these little things bring life into a model :thumbs_up_1:
Christian
AKA "Painter"
LE BOSCO
Post by LE BOSCO »
HI gents
thank you christian!
As you were able to notice it,my step by step is very slow!!!but, I redoes many thing on my richelieu,and the last redone part is the crane
To the left the part of trumpi,and the left my part In progress
To the right,the crane whit the new mast of load from the l'arsenal and to the left .....No comments
The base of the crane ended
All the redone parts
to the left , is the new head of mast of load,and to the right the pulleys no pr�sents in the kit
The ended set, assembled temporarily, and ready to be molded!
I hope that I do not annoy you with my step by step
best regards
Nicolas
navydavesof
Post by navydavesof »
This is an interesting build to follow. The attention to detail presented is very impressive. I look forward to more!
richtea
Post by richtea »
It's not annoying, Nicolas it is a fascinating build.
Your attention to detail will end up with a museum quality build.
Keep up the good work.
Regards
Richard :thumbs_up_1:
SI VIS PACEM,
PARA BELLUM
mabmanu
Post by mabmanu »
Bonjour Nicolas .
Travail des plus minutieux ... :thumbs_up_1:
a+
patrice
LE BOSCO
Post by LE BOSCO »
Thank you gents for your feedback!Thus I can continue you annoy ,with my small plastics parts!!
best regards
Nicolas
Dave Rowe
Post by Dave Rowe »
Your builds are never annoying Nicolas, I look forward to your updates :thumbs_up_1:
LE BOSCO
Post by LE BOSCO »
Hello gentlemens!
Pictures of my last "master" it concerns the double mount of 100mm
the artillery without the protection
The same, with the protection :-D
the final model will be in four resin parts,easier to mould!!
best regards
Nicolas
the original parts :Mad_6:
Stefano Salesi
Post by Stefano Salesi »
your work continues to please my eyes. really, really beautiful. your attention on details is admirable.
LE BOSCO
Post by LE BOSCO »
HI stephano
thank you for your kind comment !
regards
Nicolas
