Calling all Oliver Hazard Perry-class FFG fans
Seasick
Re: Calling all FFG Fans!
Post by Seasick »
The Deal with the Perry class: USN Perry class ships landed the Standard Missile in FY2003. The Standard Missile one medium range (RIM-66E) can't counter missile threats that materialized in the 1990s. The Mk13 launcher has been deactivated in place, the missile launcher's arm has been removed. The Strike down equipment on the superstructure has been removed. The STIR antenna has been removed. The Combined antenna system is in place. To make up for the loss of Harpoon adapters have been provided so that cells in the torpedo magazine can hold Penguin anti-ship missiles and Hellfire missiles for launch from MH-60R (SH-60B upgraded). The Bandstand is the new home of the 25mm Stabilized Bushmaster. The 25mm like the 76mm is gyro-stabilized to compensate for the ships roll while firing. The Phalanx gun has been upgraded from the Block 1 to the Block 1B standard. With longer barrels that are in a brace, an IR and visual camera/scanner on the side for attacking light aircraft, and surface targets. There is also a newer type of radar in the top of the dome that is harder for enemy missiles to detect and evade. If needed RAM missile (RAM, or SeaRAM) can be fit. Getting rid of the standard missile enabled the USN to keep the Perry class in service. Why this was is political and I'll leave that for the Off Topic area.
? Seasick?
carr
Post by carr »
el Cid
Post by el Cid »
The outriggers on the forward superstructure were for UNREP, probably just for SM1 or Harpoon transfer (same for forward VERTREP station.
Missile onload and offload to or from the magazine was accomplished with a special carriage or cart that rolled onto a special ramp that would be installed on the deck port side forward of the launcher. The cart with missile had kind of a ball hitch type fitting so that when the cart was properly positioned on the ramp, the Mk13 launcher would engage it and elevate so the missile could be transferred to the launcher rail. Then the cart would be disengaged and the launcher returned to the stow position and the missile downloaded to the missile mag.
Clear as mud?
Late entry - I found this site that explains better than my 25 year old memories (http://www.tpub.com/gunners/191.htm).
HTH,
Keith
Shot inside an Oliver Perry class FFG Hangar:
http://www.navy.mil/view_single.asp?id=140827
USS Klakring FFG-42 and not "Klakering" as noted on the page.
sundowner
Post by sundowner »
Hi
I'm just getting back into warship modelling and have ordered the Academy 1/350 FFG-7 but I was wondering what extras are available for this model?
Also are there any good reference material out there? i.e. Books [I know about the Navsource website.]
Any help you guy's can give me would be greatly appreciated.
Regards
Michael
MasterModel of Poland has a small set of brass aerials and a gun barrel that I like. There's also the Veteran Models product line, for example, they have a Mk 36 torpedo launcher (actually a Mk 32 as far as I can find) and Mk 38 gun set that might be useful (note that this is a link to Lucky Model, who currently lists it as "available." This is different than "in stock" and means that they don't have it in stock, but are pretty sure they can order and get more. This detail causes confusion with some buyers). Their SLQ-32 & SRBOC Chaff set might be of utility if you don't like the kit chaff launchers.
There's also more, but I'll stop there for now, have to get back to work!
GTDEATH13
Post by GTDEATH13 »
KA models makes pe sets for both versions:
http://www.ka-models.com/index.php?rout ... uct_id=327
http://www.ka-models.com/index.php?rout ... uct_id=480
The Master model aerials are real jewels. :thumbs_up_1: :thumbs_up_1:
NIKOS (NICK)
sundowner
Post by sundowner »
Thanks for the help. I want to get them all :) Rats, I had originally thought that i would build it Out of the box but now my AMS has taken over again. :big_grin:
Regards
Michael
davidwaples
Post by davidwaples »
If you're interested in doing a conversion to the current configuration take note of this new release from Veteran Models. Mk. 38, Mod 2, 25mm Bushmaster. All you need to do now is scratch build the gun platform.
Dave
Image[/URL]
sundowner
Post by sundowner »
Ok So I this is what I have so far... I have the Basic FFG-7 Kit. I got the Brass Aerials, Veteran models MK-38 Gun & CIWS with FLIR
and Mk1 Brass Etch set & Hawke Decals. Thanks everyone for helping to empty my pockets :) Now i've just got to figure out what ship to do?
What are my options?
Regards
Michael
USN or ??
http://en.wikipedia.org/wiki/Oliver_Haz ... ss_frigate
Fifty-five ships were built in the United States: 51 for the United States Navy and four for the Royal Australian Navy (RAN). In addition, eight were built in the Republic of China (Taiwan), six in Spain, and two in Australia for their navies. Former U.S. Navy warships of this class have been sold or donated to the navies of Bahrain, Egypt, Poland, Pakistan, and Turkey.
sundowner
Post by sundowner »
Yes I would like to do USN. I just need to choose which one!
Well, the kit gives you the parts to do both the earlier and later boats, albeit the instructions only show the earlier pieces.
If you want "significant" OHPs I'd say Stark and Samuel Roberts are well known for surviving damage. Nicholas took part in the first surface action against Iraqi forces in the First Gulf War...
GTDEATH13
Post by GTDEATH13 »
Does anyone know if the AFV club 1/350 scale OHP kit is still available? The ROCN option I mean.
NIKOS (NICK)
Don't ever mix up PLAN with ROCN! You'll have a lot of angry Chinese (PLAN) and Taiwanese (ROCN) people on your hands.
That said, here: http://www.freetimehobbies.com/AFVSE735S1/
One in stock, so be quick!
GTDEATH13
Post by GTDEATH13 »
:Oops_1: :Oops_1: :sorry: :sorry:
Thank you Tim... Sorry for my confusion...
NIKOS (NICK)
sundowner
Post by sundowner »
Does anyone know what ships are fitted with the Mk38 mount on the bow? I know of the Ingraham, the Elrod, The Reuben James, The Ford & the Kauffman. Any others?
Regards
Michael
Jimmy Conway
Post by Jimmy Conway »
davidwaples wrote:If you're interested in doing a conversion to the current configuration take note of this new release from Veteran Models. Mk. 38, Mod 2, 25mm Bushmaster. All you need to do now is scratch build the gun platform.
Dave
Image[/URL]
Thanks.....Pay attention that Nulka is there....................
Best: Jimmy
Make your influence positive!
Breton Fisherman's Prayer
Jimmy Conway
navydavesof wrote:All you have to do is google search "NULKA launcher" and you will find a lot :big_grin:
As you can tell they're kind of big.
......Nulka launchers.................
sundowner
Post by sundowner »
Hi
Does anyone know what thee may be on this picture of the USS Halyburton? I've highlighted the two things I don't know about. Is that some sort of RV Helicopter?
