Calling all Essex-class (Cold War configuration) fans
BB62vet
Re: Calling all Cold War Essex-class Fans!
Post by BB62vet »
PH,
I had forgotten about HORNET - that would also be a good ship to tour for equipment photos, etc. If you got any photos of winches, fire control directors, pumps, etc. - any deck gear, please post. They always help the modeler in his projects!
Plastic Habit
Post by Plastic Habit »
Sure will BB.
Unfortunately I do not have any looking directly at the stern
or good pics of the portaft quarter of the ship.
There was a private event the day before and sections were
either shielded or obscured from view due to moved aircraft and helicopters.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:44 pm, edited 4 times in total.
Plastic Habit
The museum is trying to maintain and restore her to how she looked at decommissioning in 1970.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:44 pm, edited 3 times in total.
Zero bubble
Post by Zero bubble »
I know that this topic has been discussed before. I didn't find any answers in the threads however.
My question has to do with the side plating on the SCB Essex class ships. I just purchased the AOS USS Intrepid book. There are beautiful plating diagrams in there, especially at the bow and stern. These drawings depict the ship prior to 27 Charlie though. I was aware that this would be the case prior to purchasing. This book will still be extremely helpful. The area of confusion is the area where the Blisters were added. Closeup pics of the Museum Essex Class ships, show an entirely different plate scheme along the sides from what was original construction. All plating appears to be butt-welded on all sides, and in a Grid pattern. Not staggered or overlapped. Somewhere I read that Oriskany being built to SCB-27A standard prior to launch, the plating system up forward was simply extended aft, around the blisters. I can't find a clear enough photo of Oriskany to verify this. I am also not a qualified diver either, so that's out! Photos that I have of Hornet's sides are good enough to go by but I still need to know what frames the blisters ran between in order to be accurate. Short of traveling to NYC, I imagine that several of the Floating Drydock prints would show this but which ones ? I would love to see some yard photos showing the blisters being installed on these ships. I found a simple drawing showing how it was done on Midway. If it was done anything like that, would certainly explain the radically different appearance in the plate work. Any suggestions?
On the drawing boards: 1/144 scale SCB-125 Essex Class carrier
Plastic Habit
Welcome to the forward port sponson of the USS Hornet CVS-12.
In the following photos is the sponson with a 5 inch gun, surrounding catwalks, and rooms through the bulkhead openings.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:46 pm, edited 3 times in total.
Zero bubble
Plastic Habit wrote:Welcome to the forward port sponson of the USS Hornet CVS-12.
The red numbers are something I have added to help give orientation in the views, they are not on the actual ship.
Plastic habit. Very nice photos. I had been looking for images of that very area for a long time. My assumptions after looking at the print is evident in the photos. The openings to the handling rooms are without doors on the port sponson. It is great to be able to see that without having to travel for now. I was wondering about the Stbd side. It looks like a slightly different arrangement. The print shows at least two Watertight doors in that location. Do you have any photos of the Stbd fwd sponson as well? Something else I can't seem to find photos of are the aircraft fueling stations/hose reels. Did you happen to take any pics of those? Once again, excellent pictures.
Dick J
Post by Dick J »
Zero bubble wrote:My question has to do with the side plating on the SCB Essex class ships. I just purchased the AOS USS Intrepid book. There are beautiful plating diagrams in there, especially at the bow and stern. These drawings depict the ship prior to 27 Charlie though. I was aware that this would be the case prior to purchasing. This book will still be extremely helpful. The area of confusion is the area where the Blisters were added. Closeup pics of the Museum Essex Class ships, show an entirely different plate scheme along the sides from what was original construction. All plating appears to be butt-welded on all sides, and in a Grid pattern. Not staggered or overlapped. Somewhere I read that Oriskany being built to SCB-27A standard prior to launch, the plating system up forward was simply extended aft, around the blisters. I can't find a clear enough photo of Oriskany to verify this. I am also not a qualified diver either, so that's out!
If I understand the process correctly, the word "blisters" is almost a misnomer. I believe it is more accurate to say that the hull was widened rather than blistered. At the forward and after ends of the widened area, the hull plating was removed and the new plating went smoothly from the original bow and stern areas around the new side framing. I think that the outer ends of the original side longitudinal stringers were "reconnected" with new stringers in the widened area to make the "blister" an integral part of the hull structure. This worked because the hangar sides and flightdeck were all superstructure and it didn't matter if the superstructure aligned with the hull or not. As a result, you wouldn't see the transition lines from original hull to "blister" like you see on the Midway or the Arizona. Part of the original side plating was removed to extend some upper hull compartments out to the new hull side. There are a couple of Navsource pictures of CV-16's modernization that show this to some degree.
http://www.navsource.org/archives/02/021623.jpg
http://www.navsource.org/archives/02/021625.jpg
Plastic Habit
Hey Zb,
Unfortunately I was unable to access that particular sponson. Partially due to the private event from the day before,
but there also seems to be some work going on as evidenced by the tenting in the first sponson pic.
I have tried to compile some pics that will hopefully help you.
I have used the drawing you provided to label the corresponding pic locations, these are in red.
I'm not exactly sure which doors you are referring, but I have labelled two which I am hoping are the ones, there are in green.
The first (1), the one to Gas Station #5 is obscured by the radar.
The second (2) is immediately aft.
Last edited by Plastic Habit on Tue Jul 07, 2015 11:42 am, edited 2 times in total.
Zero bubble
Yes, those are for sure JP-5 hose reels on the Hangar deck. The purple painted piping (say that three times fast) indicates this. Any pipes with that color contain or contained JP-5. Some things don't change much. I remember using that same type of reel on an MSC ship that was built in 1994. I am still wondering about the openings to the GAS-STAs. I am curious still how the hose(s) ran up to the flight deck. I don't think there is any hole in the deck, at least that I can see. In one of the pics it looks like there is a type of roller chock at the edge of the flight deck. My guess is that the hose ran out the doorless openings and up and over the rollers.
Another question I have is: did you take any pics of the edge of the main deck. Ie: the weather deck area in the vicinity of the island, or on that whole side actually. I'm trying to figure out how the "gutters" (gunwales) "drain troughs" ect look like. And do the run under or around the closed chocks and other fittings. This is how it is on the Massachusetts. Sometimes there is just a lip with drain spouts every so many feet. I realize that there are several sponsons on the Stbd side main deck. I'm more concerned with the flush sided areas. I would be curious to see how the drainage is set up on those sponsons as well though.
Zero bubble
Dick J wrote:If I understand the process correctly, the word "blisters" is almost a misnomer. I believe it is more accurate to say that the hull was widened rather than blistered. At the forward and after ends of the widened area, the hull plating was removed and the new plating went smoothly from the original bow and stern areas around the new side framing. I think that the outer ends of the original side longitudinal stringers were "reconnected" with new stringers in the widened area to make the "blister" an integral part of the hull structure. This worked because the hangar sides and flightdeck were all superstructure and it didn't matter if the superstructure aligned with the hull or not. As a result, you wouldn't see the transition lines from original hull to "blister" like you see on the Midway or the Arizona. Part of the original side plating was removed to extend some upper hull compartments out to the new hull side. There are a couple of Navsource pictures of CV-16's modernization that show this to some degree.
Thanks Dick. That was very helpful. I apologize, after going through this entire thread again last night, I saw where you had explained this before. I saw a similar image of CV-19 while on NAVSOURCE. That is ironic because although undecided yet, I am leaning toward modeling the Hancock. She was built locally, has a local name, and had a long career. Quite a few CV-9 hulls have Bay State namesakes come to think of it. Q: do you own a copy of Alan Raven's book? As nice as I imagine it must be, I am trying to avoid spending the dough. I one were to insist on detailing all the side plate work on his or her model. What would be the best reference for the price. I really wish I could find some hi res close up shots of Oriskany when she was pier side @ Pensacola. The rust and peeling paint obscures the seams too much on all the pics I've found online. I would really like to compare her sides to photos I already have of other hulls. Perhaps someone here can point me in the right direction
Reason: Fixed quote
Plastic Habit
Ok, so here are some of the photos of the closed chocks that I have from my pics.
They are of the starboard side and start forward and run aft. For the ones I could I tried to give
the general area then a more close-in view.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:47 pm, edited 3 times in total.
Zero bubble
I found this one on NAVSEA' inactive ships div page. Oriskany @ Pensacola prior to sinking. 2 items here: 1. that forward part of the Stbd main deck weather deck has the extension over the side. I don't know for certain but by the look of welded seams on the deck, you can see the width of the blister.
2. Although it's not the actual main deck edge in this area, this is what I was trying to find out how the closed chocks sit as well as the drainage setup. I think there is another name for these projections/platforms that extend out from the main deck in different locations. I'd call them sponsons but did not want them to be confused with the gun tub/sponsons. I would still like to find a photo of the actual main deck edge taken from on board one of the ships. The AOS book is finely detailed with the various stanchions and fittings. Not much about the horizontal surface at the deck edge though.
This shot is of the Iowa's main deck.  It's the same on the Massachusetts. There is "gutter" between where the teak ends and the top of the sheer strake.  Drainage runs under the closed chock. From the pics that. Plastic Habit just posted looks like the chocks are different, and hang overboard slightly. I'm curious about how it looks while standing on the main deck.
Zero bubble
Plastic Habit wrote:Ok, so here are some of the photos of the closed chocks that I have from my pics.
Great shots PH. Those are very helpful, not only for my deck edge question but also very good for determining where a lot of the welded seams are on the hull. I think it's safe to say that the longitudinal riveted plate (20 or so inches tall) probably encompasses the area fore-aft where the blisters run
Plastic Habit
For your enjoyment.
From the starboard side, not sure about the technical term, so I will call it:
Emergency Barrier Pylon Hydraulic Cylinder
The pylon is in the upright position.
Last edited by Plastic Habit on Tue Jul 07, 2015 11:45 am, edited 2 times in total.
Zero bubble
That's a nice detail. I've never seen any photos of those either
Plastic Habit
A little more.
Port side whaleboat stowage under flight deck.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:48 pm, edited 3 times in total.
Plastic Habit
Port side Emergency Barrier.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:49 pm, edited 3 times in total.
Plastic Habit
Starboard Emergency Barrier Pylon.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:34 pm, edited 2 times in total.
Plastic Habit
Starboard Emergency Barrier Pylon pit.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:35 pm, edited 3 times in total.
Zero bubble
Plastic Habit wrote:Starboard Emergency Barrier Pylon pit.
Wow, great pics. Nobody should have any problems depicting that system now! That just saved me a days worth of research. Thanks P.H.
Return to “Aircraft Carriers”
