Calling all Essex-class (Cold War configuration) fans
Plastic Habit
Re: Calling all Cold War Essex-class Fans!
Post by Plastic Habit »
And more.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:51 pm, edited 2 times in total.
Plastic Habit
More.
Last edited by Plastic Habit on Thu Sep 17, 2015 6:57 pm, edited 2 times in total.
Plastic Habit
And of course more.
Last edited by Plastic Habit on Thu Sep 17, 2015 6:58 pm, edited 2 times in total.
Plastic Habit
Here are some more. Ok, it might get a little boring for the next few sets.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:52 pm, edited 2 times in total.
Plastic Habit
Ok, these might be a little bland.
Last edited by Plastic Habit on Thu Sep 17, 2015 6:59 pm, edited 2 times in total.
Plastic Habit
Guess that was not so bad. And more.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:00 pm, edited 2 times in total.
Plastic Habit
Ok, maybe back to bland a little.
Plastic Habit
More.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:01 pm, edited 2 times in total.
Plastic Habit
Where did the starboard side go?
That's pretty much it for my pics of that side.
I still have a few from on the ship.
Last edited by Plastic Habit on Thu Sep 17, 2015 7:02 pm, edited 2 times in total.
Zero bubble
Post by Zero bubble »
maurice de saxe wrote:
According to Norman Friedman, the blister ran from Frame 54 to Frame 175 parallel in width to the existing hull. The shell plating was removed between Frame 39 and Frame 54 forward and between Frame 175 and Frame 195 aft, and replaced with new tank sections that faired into the parallel blister section.
Maurice
And here it is ! These are from Oriskany's drawings, so the blisters may have been a bit longer with the wider beam on this particular ship.
Plastic Habit
Hey Zb,
Found these two views in my pics. They are from the main deck starboard-aft quarter area.
Hope they help you a least a little.
Zero bubble
Plastic Habit wrote:Hey Zb,
Thanks a bunch PH. Keep up the good work
Would you have any shots showing the area where the arrow point is hidden?  Taken onboard the ship ?
Plastic Habit
Sorry Zb. I have nothing showing that area or other portions like it.
Hopefully, the next time I go there will not be nearly as much closed off.
Gator52
Post by Gator52 »
I'd like to build Lexington as she appeared in the 80s; are there any major showstoppers with the Gallery Intrepid kit as a basis?
I haven't used any Tetra sets before, how is there PE for this kit? Any aftermarket for training wing aircraft out there?
Jonah
Dick J
Post by Dick J »
Lexington had a totally different bow configuration than Intrepid and the starboard elevator and crane need to be transposed. There were also differences in the after end of the flightdeck. A bit of scratch building, but it depends on how much of that you are willing to do.
Mark McKinnis
Post by Mark McKinnis »
There was a thought and some movement on the Gallery side to make a Ticonderoga and there was rumors of a conversion set to make a Yorktown using the Intrepid kit as a base. I guess all of that is dead now. Bummer! I am still planning on doing an Oriskany some day. I was hoping that one of the conversion sets would come out and beat me to it.
Tico/Hancock not much of a stretch but any of the others require everything Dick J mentioned and then some.
Hank McCoy
Angles ? of Deck and Steam Cats
Post by Hank McCoy »
Can anyone tell me the actual angle that the Landing Deck is on for Essex class ? (I know Antietam was a one-off) Do all current US carriers have the same angle ? (ie. Do pilots approach each carrier the same way or are there differences ?) Also, the Steam Catapults have an offset to starboard. What angle is this .. and why ? Thanks.
MAJOR-B
Post by MAJOR-B »
Question of 1/350 Aircraft kits currently for sale. Which ones can be used to make the flight deck look right for a 69 version of Tico or Hanna. Finally when did they start using SH-3 Seakings and which kit should be used.
Thanks...
Major B
Mark McKinnis
MAJOR-B wrote:Question of 1/350 Aircraft kits currently for sale. Which ones can be used to make the flight deck look right for a 69 version of Tico or Hanna. Finally when did they start using SH-3 Seakings and which kit should be used.
Thanks...
Major B
I like:
Corsair Armada F-8 Crusader
Corsair Armada RF-8G Crusader
L'Arsenal A-4 Sky Hawk. They are not the "Hump Back" version. Corsair Armada's A-4s have a "Hump Back" version but are a little over scaled. I planned on using my Corsair Armada Sky Hawks for drop tanks and hump back for the L'Arsenal Sky Hawks. ( Kind of a pricey way to do it)
E-1 ( The Intrepid Kit comes with 2 of them)
UH-2 ( The Intrepid Kit comes with 4 of them) or Trumpeter SH-3
Trumpeter A-3B
Tico http://www.gonavy.jp/CV-CV14f.html
Hanna http://www.gonavy.jp/CV-CV19f.html
SH-3s came in 1970 when Tico became a CVS and Hanna got them in 1972 as a CVA. Tico got two squadrons of A-7Bs in 1969 which I would use the Trumpeter Kit if I were to do that era for Tico. I am not a fan of the photo etch main landing gear on the L'Arsenal F-8 Crusaders. I am using a lot of spare Tamiya A-7E kits for their main mounts but it would be a pricey way to go if you want to do that. I already had a bunch of them. Otherwise they are very nice for the Crusaders.
Good Luck!
Mark
Mark McKinnis
Re: Angles ? of Deck and Steam Cats
Hank McCoy wrote:Can anyone tell me the actual angle that the Landing Deck is on for Essex class ? (I know Antietam was a one-off) Do all current US carriers have the same angle ? (ie. Do pilots approach each carrier the same way or are there differences ?) Also, the Steam Catapults have an offset to starboard. What angle is this .. and why ? Thanks.
I do not know the actual angle but they were different between the class of carriers. Since all of the Carriers are Nimitz Class today, they are the same. Friedman's "The U.S. Aircraft Carriers" book has that info. The Steam Cats on the Essex Class were angled because they were longer than the Hydraulic Cats and there was not enough space in front of the Island to taxi a jet into position on Cat #1. ( The Starboard Cat).
Return to “Aircraft Carriers”
