Calling all Queen Elizabeth-class (1914-1947) fans
blw
hoses, reels?
Post by blw »
I'm building a QE from 1918. The Artist Hobby PE kit has literally a couple of DOZEN reels. There are five cast onto the deck of my kit (Trumpeter), and two more mounted on the side of the superstructure below the bridge. I looked at every QE-class photo that I have, including RA Burt, and I can come up with only one or two more. None of these locations are aft of the boat deck. Four of them are right up front under the guns of A turret, behind the breakwater. Am I missing a few?
I assume that these are fire fighting equipment - but QE was of course one of the first oil burners. Where were provisions for oil hoses kept? They seem to be very large hoses from the UNREP photos I've seen - but then again, they might well be with every oiler and dock, rather than with the ship.
... Brian
RNfanDan
Re: Calling all HMS Queen Elizabeth class fans
Post by RNfanDan »
Those mounted on bulkheads below the bridge, were likely CORDAGE reels. Generally smaller and lighter than the heavier HOSE and HAWSER reels. From my available 1918-era Q.E. resources, I find a total of SIX deck-mounted reels, including the four you noted that were abaft the breakwater.
Two others are seen on the boat deck, both of them to port of the ship's centerline. There appears to be one more, but I cannot tell if it is a deck-mounted reel (making a total of seven), or attached instead to the port-side bulkhead of the aft shelter. These boat-deck reels, whether two or three in number, do not "look like" hose reels.
Wish I could be of more help... :huh:
George Hargreaves
Post by George Hargreaves »
Hi,
Go to the Warspite site at http://www.warspite.dk/super.html. Click on items in the image in the upper left corner. This is a super CAD drawing that shows a variety of interesting things. The site is well worth exploring.
There are also reels for wire cables. These can be mounted on any surface and are small.
George
blw
Post by blw »
Thanks Dan- apparently I'm not blind (which I was beginning to suspect!)
... Brian
blw
Post by blw »
George - that's certainly an interesting site, although I didn't find anything that would relate to this specific question. I guess I need to figure out something about CAD. It's just getting too prevalent in too many areas of modeling to ignore.
I also had a bit of trouble seeing most of that site from my iPad, although it seems to have loaded fine on my computer, if others are having trouble later.
... Brian
anj4de
Post by anj4de »
Hello all
I have a QE here as well and am looking at this set...
http://www.boystownmilitaryminiatures.c ... 66720.aspx
Is this a good option and are there any opinions on the seller? Just found it while googling and the price seems right!
thanks
Uwe
You might say the seller is "infamous" - this thread should give you some insight: viewtopic.php?f=2&t=154644
Dick J
Post by Dick J »
I have a question RE Warspite's secondary battery. When the ship was modernized, the battery was reduced. Were the remaining guns also relocated or just reduced in number? The reason is that I just received a 1/700 Warspite kit along with Barham. Warspite's 6" guns don't seem to align with any on the Barham. Shouldn't they line up?
igorp
Post by igorp »
Dick,
according R.A. Burt Battleships 1919-45:
Forecastle flare was extended aft almost to A turret and widened so that the side flushed with what was formerly the second 6in gun port. The side was plated up over main deck casemates aft and decked over.
Based on this and the drawnings in this source, no relocation.
Dick J
Post by Dick J »
Thanks Igor! That leaves me with some questions. 1. How far do the guns have to be moved to correct this? and 2. Is it worth the effort? Decisions ... decisions .....
igorp
Post by igorp »
You are welcome.
To help you with q.1, there is a drawning here, probably from Profile Morskie. I can send you Mr. Burt drawning also. Just let me know.
Ady
Post by Ady »
The first and last casemates were removed.
NVNC EST BIBENDVM
Haijun watcher
Post by Haijun watcher »
So let me guess this straight...if I used the Trumpeter 1/700 Warspite and Queen Elizabeth WW1-era kits, will I be able to model the RN Grand Fleet's 5th battleship squadron at Jutland?
The ships in the squadron were:
Barham
Valiant
Warspite
Malaya
Or the differences between these sisters are too numerous to use multiple copies of either Trumpeter kit?
Ady
Post by Ady »
Both kits are the same and represent QE in 1918. They are very much different to the appearance of any of the ships at Jutland.
NVNC EST BIBENDVM
Haijun watcher
Ady wrote:Both kits are the same and represent QE in 1918. They are very much different to the appearance of any of the ships at Jutland.
Thanks. So Trumpeter didn't put enough research into making the Warspite 1915 kit? Oh well...
On a slight off-topic, the thought of using the upcoming 1/700 HMS Dreadnought from Trumpeter was also attractive, but the actual Dreadnought missed Jutland...
Our local IPMS here in Vancouver/Burnaby, BC, Canada has the theme of "World War One" for its October show, which is why a Jutland modelling subject interested me...
blw
Post by blw »
The Artist Hobby Queen Elizabeth upgrade set has significant options for pre-1917 details, and the PE is very, very nice. I haven't actually checked the set against a Jutland configuration, though.
... Brian
prowler0000
Post by prowler0000 »
I'm nearly done with my Trumpy 1/350 Q.E.
Just the ships boats & some ladders to go.
So.......
What colour are the ships boats? Are any of em blue? Coz i quite like the look of some blue boats.
Thank You all for any forthcoming help!
richtea
Post by richtea »
Blue, green or grey, it's your choice, the senior officer makes the decision.
Regards
Richard :thumbs_up_1:
SI VIS PACEM,
PARA BELLUM
prowler0000
Gunze blue won the day. :thanks:
Good to be the commanding Officer! :jest:
AndyP
Post by AndyP »
Can anyone advise if the Pontos upgrade set will fit the Trumpeter Warspite kit (1/350) specifically the deck, since I'm reasonably sure the masts/barrels etc will fit without to much trouble ;)
cheers
"Wow, how'd you get it to work?"
"I ran a Physical Impulse Mechanical Stress Routine"
"Huh?"
"I kicked it."
"Ahh."
