1/350 RICHELIEU Dakar 1940-41
sirmaumau
Re: 1/350 RICHELIEU Dakar 1940-41
informative and instructive?
J. Aguilar
Nicolas have gold in your hands, scratch very neat and clean, impressive.
cheers
JAM
cheers
JAM
- LE BOSCO
HI all
thank's Jam
The work continuous on the diffuser of the chimney
The left part is the Trumpy (false
the diffuser is in fact composed of six independent diffusers, each is composed of a kind of at four blades shutters, the simultaneous opening of four blades, is actuated by a rod assembly (in stretched black on my piece)
for a port configuration (in stop) apparently one diffuser, rest open (group allowing a power electric) if the object of my dio Richelieu was at sea and in working order, the six diffusers must beings opened .I also redid the external piping on the chimney
And those on the sides
I think I'm going partition off the outputs, injected of the resin, and mold the all!!!
I also did the gateways on sides of rangefinder bloc
A view of two pieces reunited
And finally, a view of the progress of the "work"
That advance, that advance, slowly, but surely
Nicolas
thank's Jam
Nicolas
- ArizonaBB39
Fantastic work Nicolas!
- Bigdaddy Mark
She's looking good.
Bigtime difference in that stack.
~ Chester W. Nimitz ~
- LE BOSCO
ArizonaBB39 wrote:Fantastic work Nicolas!
thanks to you both
thanks for your participation
Nicolas
- LE BOSCO
Hello folks
I had promised Christian Brauer, the mounting steps for the manufacture of a platform.
But it may be of interest to some people
For begin cut off the �floor� in the plastic card of 0.50, cut off walls made of plastic card 0.20, and glue them onto one side (make sure of squareness of the wall)
Once dry, fold the "wall" and put glue extra fluid in the junction "wall" - "floor"
Have made the same thing with small edges presents top of the �wall�, it's made in stretched sprue
The result
Now something a little more complicated! Under the platforms, are present two bracket of reinforcements perforated. Here are the materials to realize them
The plastic card is of 0.30
The result
saw the pettiness of parts, must be a� little rigorous� but nothing impossible
Then, a small game of patience, the gluing of gussets and reinforcements
The result ,with the original part
And temporally placer on the chimney
I got rid of this step, and I can move on something else
Nicolas
The result
The result
Nicolas
- boomstick68
Very nice Nicolas.
- Channell
Wow, I get aggravated just gluing PE parts twice that size... but making it out of styrene card and making it fit so flawlessly at such a small scale... Nicholas, I want to be like you when I grow up!
-Jason Channell
- PetrolGator
Did you simply cut these supports with a straight razor blade? Wow.
- Chris
1/700 Murdertorpedoboat Ooi
- LE BOSCO
many thank's gentlemen's
PetrolGator
it is amazing what can be done with a simple razor blade ,in more it is not expensive
Jason
you wrote "I want to be like you when I grow up!" It's funny, I say the same thing looking at the work of some, Jim Baumann to mention only him
cheers
Nicholas
PetrolGator
Jason
cheers
Nicholas
- LE BOSCO
Hello Folks
Faithful to my rhythm, of small progress on my chimney, I remade entirely the upper platform (I had been mistaken within forms) superstructure was also completely redone.
The platforms projectors are definitely glued and the tubes of the remote control devices are installed at this stage
I starts to added of details (ladders, pipes ...)
A view of the entire block chimney , it starts to take shape
And as I am a lucky man, I had the firsts planks of PE from L�ARSENAL on French catapults to 350 em
And the superb new LOIRE 130 at 35 0em always from L�ARSENAL
I'll put it all out on my Richelieu soon
Nicolas
Nicolas
Plastic Habit
Wonderful work on that chimney. Definitely going to have to pay attention on how you put things together. Im still working on my first ship so making stuff for them is totally new for me. Cant wait to see more.
sirmaumau
it seems that the cats were for dunkerque and other cruisers, not for richelieu
- LE BOSCO
sirmaumau wrote:it seems that the cats were for dunkerque and other cruisers, not for richelieu
Hello
Plastic Habit,thanks for your interest
Sirmaumau
what are you calling "the cats"??????
regards
Nicolas
I believe Sirmaumau means Cats = catapults.
Beautiful work as always, Nicolas!
- LE BOSCO
thanks for your comment
and your explication for the "cats"....but for me a "cats" it is a thing that makes meow
but this "cats" are good for the Richelieu
regards
nicolas
regards
nicolas
- Chlo� Plattner
Hi Nicolas,
as usual I am deeply impressed of your precise scratch built platforms. They are far ahead of kit parts ever. I really love to follow progress on your amazing model.
with best rgeards
Peter
with best rgeards
Peter
A passion for modeling
- ArizonaBB39
Superb, clean work Nicolas, thanks for sharing!
- Christian M.
- Location: Cologne / Germany, sometimes Poznan/ Poland and Chessington/ UK
As far as I know most catapults of a Navy are standard and so the same at least. Looking for example on all the US Dreadnoughts which survived Washington Treaty and being modernized before WW-2, they have same type of catapult as have the new BB's build after Treaty was out to garbage. The same on other ships of other Navies too, so I suppose it was in French Navy the same situation too...LE BOSCO wrote:Timmy C
thanks for your commentand your explication for the "cats"....but for me a "cats" it is a thing that makes meow
regards
nicolas
