1/350 Yorktown CV5 Battle of Coral Sea
TF17Greg
Re: 1/350 Yorktown CV5 Battle of Coral Sea
Post by TF17Greg »
Iceman 29 wrote:Nice job! :thumbs_up_1: :cool_2:
Thanks Pascal merci beaucoup :big_grin: :big_grin:
CUT...FILE...GLUE...PAINT...WEATHER...AND...REPEAT :wave_1:
Follow me on YouTube https://www.youtube.com/@Fullmetalpainter
TF17Greg
Post by TF17Greg »
Dear all....after checking a couple of pictures ( mainly the elevator of the Enterprise) of the elevator l made this extra work...not finished yet... :wave_1:
TF17Greg
Post by TF17Greg »
DavidP wrote:trim them down as they stick out too much in relation to the picture.
I most defenetely will...Sir :big_grin:
TF17Greg
Post by TF17Greg »
As per promised....
I finished the edge of the elevator and l started the wall in front of it....
Enjoy
TF17Greg
Post by TF17Greg »
Dear all here is today's update...so l prepared the holes for the 2 other elevators and added details (cable reels) on the bow structure...enjoy
TF17Greg
Post by TF17Greg »
DavidP wrote:your 4 vertical "+" beams are located in the wrong spots plus missing a round post between the back 2 "+" beams. your frame work should match Pascal's framework https://i.postimg.cc/BvYQBt4y/Screensho ... 48-320.jpg with the vertical "+" beams located on the longitude beams #2 & #4 like this https://i.postimg.cc/cLWmzv1k/Screensho ... 19-537.jpg
Thanks DavidP for your comment
1. I don�t see where m'y 4"+" beams are wrong (check the picture of the original plans)
2. Thanks for the info on the 2nd round post
3. I don�t have the PE set for matching Pascal�s superb work
TF17Greg
Post by TF17Greg »
OK DavidP....
Got your point but still if you look at the plans l don�t see what you mean... and l think there is a mistake there are only 4 beam (red ones)
I think l will scratch build the structure since in the kit (the one l did so far)is not correct and l will try to do it like this you can see that the central beam is not present...
TF17Greg
Post by TF17Greg »
Well....DavidP thanks to your comment l found out the mistake of the structure
The kit structure is 1.42mm thick which is waaayyyy to big so l will scratch build it in 0.6 or 0.7mm thick plasticard since in metal will be to difficult to cut and glue....(l'll try in metal but l don't think it will be ok)...
Have a nice evening
TF17Greg
Post by TF17Greg »
Dear all here is today's update...well as l supposed the copper foil that l have it's way too thin...so l decided to use 0.6mm plasticard..still there will be corrections to do...but it's starting well....enjoy
TF17Greg
Post by TF17Greg »
Dear all here is today's update....the structure in plasticard does not work....sooooo brass and super detailling of the 2 catwalks...
Hopefully it will fit...l still have to do a lot of dry fitting...enjoy
TF17Greg
Post by TF17Greg »
Dear�all...today's update....this structure it's really complicated but rewarding..enjoy
Devin
Post by Devin »
Nice. The exterior trusses came out great.
TF17Greg
Post by TF17Greg »
Devin wrote:Nice. The exterior trusses came out great.
Thanks :thumbs_up_1:
Ditto that, and everything you've done since my last post. :smallsmile:
TF17Greg
Post by TF17Greg »
Dan K wrote:Ditto that, and everything you've done since my last post. :smallsmile:
Thanks Dan K
Dear all here is today's update on the diorama the structure is placed...still more stuff to do and some dry fitting for the beams...enjoy
marijn van gils
Post by marijn van gils »
Very nice work on those beams! :thumbs_up_1:
TF17Greg
Post by TF17Greg »
Thank u Marijn
Dear all here is today's update on the diorama....l finally finished the structure (dry fitting only) and started the elevator pit...enjoy :big_grin:
henkdepater12
Post by henkdepater12 »
TF17Greg wrote:Dear all here is today's update on the diorama Battle of Coral Sea....l present to you PORTHOLES MADNESS....boring 4 u but necessary...enjoy
Great stuff, well done.
TF17Greg
Post by TF17Greg »
Thank you henkdepater12
So here is today's update on the diorama...
Building of the stern elevator..really enjoying this
TF17Greg
Post by TF17Greg »
Dear all here is today's update...pit's stern elevator is done at 98% now the central begins..enjoy
