Calling all Ticonderoga-class (CG-47) fans
- Jim21680
Re: Calling all USS Ticonderoga (CG) class fans
I was fortunate enough to be given a tour of the USS Doyle yesterday for work (FFG-39), and was curious about the white rectangle and line across the bow.
Can someone explain it's purpose on these Frigates? (would they land a helo on the sloped bow??)
Easiest picture I could find:
http://upload.wikimedia.org/wikipedia/c ... 9_Full.jpg
I would like to have seen Montana...
- Cliffy B
Those are VERTREP or Vertical Replenishment markings. That's when a helo picks up a load of supplies via its belly hook and carries them to the ship. The rectangle indicates where to drop the load and the dashed line is a line up line for the helo.
- Bigdaddy Mark
Was looking for a 350 Ticonderoga kit. Are there any that are better than the Dragon kit? When I built the Vicksburg out of the Mobil Bay kit there was some seriously frustrating fit problems. Now I'm not even seeing that kit around. My son just got transferred to the Monetary, and I'm going to need to add one or two to my stash.
~ Chester W. Nimitz ~
It's the same kit, but have you tried looking for the Italeri Gettysburg CG 64 version?
There's no better plastic version - Trumpeter/Mini-Hobby Models made a crappy copy of the Dragon kit, but bad-upon-mediocre is...bad.
- Bigdaddy Mark
Good call. I forgot about the Gettysburg. I'll start looking for one.Timmy C wrote:It's the same kit, but have you tried looking for the Italeri Gettysburg CG 64 version?
- navydavesof
So, who's going to build the modified Tico with the side blisters?Jeffcsr wrote:Had any of the Tico's had the proposed side bulge armor applied to the hull? If so, which ships and are there any pics showing it?
- Cliffy B
Hmm....what was the time frame for said blisters?
- navydavesof
The first instance I saw it referenced was in the late 1990s USNI Ships and Aircraft of the US Fleet.Cliffy B wrote:Hmm....what was the time frame for said blisters?
- Bigdaddy Mark
I'm looking for a good PE kit for my Monterey kit. I just can't seem to find any for sale anymore. HELP!!
- Bigdaddy Mark
OK, I got my PE kit, and a lot of extras. Once everything comes in I'm going to be ready for action.
I do need help.
Does anyone have a clear picture of the RHIBs on the ship both port and starboard.
I do need help.
- krgf15
need 1/700 Ticonderoga class decals
does anyone know where I can get ticonderoga class decals in 1/700? I have two kits, and the boxes got water damaged when we moved? I googled it, and came up with nothing. Thanks.
Trevorsking
Calling all USS Vella Gulf Fans
I am new to Ship model making. I am trying to make models of all three ships I served on.
The USS Yorktown CG-48, USS Arleigh Burke DDG-51 (Plankowner) and the USS Vella Gulf CG-72 (Plankowner). My daughter bought me the USS Yorktown CG 48 model for XMAS (bless her heart) made by Cyber Hobby. I am going to buy the USS Arleigh Burke DDG-51 kit made by Trumpeter however I need to find a later version of the Ticonderoga Class Cruiser to make the USS Vella Gulf CG-72. I have heard about the Dragon/Italeri kit #5554 for the USS Gettysburg CG-64 or the Dragon USS Mobile Bay CG-59. I also heard about the the Trumpeter USS Mobile Bay kit # 80702 but it is an old kit. (All in 1/350 scale).
I have also heard and read about some issues with the quality of these kits in regard to fitting/alignment, if anyone could direct me to threads/articles about how to overcome these problems those would be appreciated as well. Unfortunately, due to suffering a TBI while on active duty, I am no longer able to work and I have plenty of time on my hands to learn how to build these right, that being said it also limits my budget but I am willing to do what it takes to learn (air brushing, fitting techniques, etc....). Thanks, Ron
Hi Ron,
I merged your question into this Ticonderoga class thread.
As to overcoming fit problems, Sgtryan13 has a build thread on it that should be educational: viewtopic.php?f=59&t=154277
For a quick and dirty out-of-the-box build of the Italeri kit by yours truly when he was 15, here's how it is without any attempt at fixing the issues: http://www.modelshipgallery.com/gallery ... index.html
Trevorsking
Thanks Timmy for the links.
Ron
Ron
Name is Ron, Trevor is my son and thinks he is the king
anj4de
Hello all
While looking for a master to cast some VLS panels for a potential 2015 Wisconsin I ran across an E-Bay deal that advertised "Bastelschrott" which actually was a Italeri Gettysburg and an Academy Oliver Hazard Perry. They are started but not much and the hulls are done nicely. No paint yet! All in all I was thinking ..."into the spare part box" but when I opened the boxes I found that each kit also contained a full WEM PE set! So I guess mid to long term at least the Gettysburg might be done. Now starting to research those new ships, I am normally more focused on WWII, I found those fantastic pics of the Port Royal after her slight accident. Now that blue belly is a killer!
It adds to the already futuristic apperance of the whole design so my build...once started/continued will be a blue bottom vessel. Now which blue belly can be easiest being build from the Gettysburg, please? Also looking at the dry dock pics it seems liker the keel of the kit is way to short. Has this been addressed by anybody yet and are there good pics that show the real size?
First thing though will be to get some silicone and resin to copy those VLS panels. Maybe one day (after re-commisioning) I will have a BB-64 accompanied by a "Blue Belly"
thanks a lot
Uwe
thanks a lot
Uwe
- navydavesof
Uwe,
So you know, the blue and green anti-fouling paint that was tested aboard the Port Royal and a number of other ships...it has been dropped. It does not work as well as the rest stuff, so the Navy has shifted back to red, fleet wide.anj4de wrote:...I found those fantastic pics of the Port Royal after her slight accident. Now that blue belly is a killer!It adds to the already futuristic apperance of the whole design so my build...
Pappy 121
G'day people,
I am getting ready to build the Italeri boxing of Dragon's 1/350 Tico. The Italeri boxing includes decals for CG-64 "Gettysburg", which is fine by me. I have a few questions though as I am primarily a jet guy.
I have been browsing on-line images of Ticonderoga class CG's and there are several differences between the ships of the class depending upon the different mod states amongst the different ships.
My questions are:
1. What are the correct colours for the the vertical and deck surfaces? (preferably in Tamiya and/or Gunze equivalents)
2. For CG-64, what colour should the exhaust stacks be painted? It seems that these vary from all black stacks, grey stacks with black tops or all grey stacks.
3. What colour should the life raft containers be? I have seen white and light grey variations.
I realise that the answers to these questions will depend upon a time period. I don't have a particular time in mind, so lets say pre-update for simplicity's sake. Judging form the kit parts, CG-64 has the VLS, Harpoon launchers, chaff launchers and the older style ship's boats.
No IRB's, bushmaster or IR modified CIWIS are included so I am assuming that these all happened post mod,
Thanks in advance,
Pappy
My questions are:
Thanks in advance,
Pappy
The 1:1 scale colours for modern USN can be found here: viewtopic.php?f=69&t=104955
For the funnels and liferaft canisters, just pick a photo that represents the period you're modeling the ship, and stick to that photo for your painting - you can't go wrong that way, as you know that she was painted that way for at least one moment in her life. The liferafts are currently the same colour as the rest of the vertical surfaces but appear to be different due to them being fibreglass; I don't how long this has been the case for, though.
Pappy
G'day Timmy!
Thanks very much, that link is exactly what I was chasing,
cheers,
Pappy
cheers,
Pappy
- marengtech
Hello,
I've just purchased a 350th Dragon kit off of Ebay and looking for PE sets and decals.
BigDaddy Mark: what scale is the PE set you got for your kit and if its 350th do you still have the contact info such as website/email?
Does anyone out there do decal sets for specific units or group of units such as the units crests, battle ribbons and E's? In particular, I'm looking for Port Royal's as she was part the battle group when I went to the gulf in 2001.
Thanks for the help!
Gerry
