1/350 french battleship RICHELIEU/l'Arsenal Upgrade Set
Re: 1/350 french battleship RICHELIEU/l'Arsenal Upgrade Set
Hi Jim, thank you for youre message, I have seen the pics from you off my Sara, thank you for that, also it,s my plan to make a work in progress off that model, I have a lot off photo,s for that but its for me because off my slow typping and poor English a lot off work. on this time I found a lot off plassure to follow the progress off the Richelieu because I am making that model also only mine model is the 1943 shape, many happy modelbuilding greethings Jos Visser
- LE BOSCO
Hello gents
in First ,a happy new year for everybody
The last ones master's made
Another rangefinder!!!with his fairing
the two pieces next to each other(by trumpy and by me)
this rangefinder is located on the roof of the bridge, just before the blokaus
in 1952 the Richelieu had two 7-meter whaleboats located at level the turrets of 152,to port and starboard
the master of whaleboat with a tarpaulin
the projectors of 120 cm which in turn are going to undergo a makeover
the basis of work
the second stage,details
once again, the two pieces next to each other(by trumpy and by me)
What's wrong
and finally, the projector in place
it's all for now,to follow, the detailing of the anchors and propellers
best regards
nicolas
the basis of work
What's wrong
best regards
nicolas
moomoon
"Et lux fuit"
You know what? I prefer your homemade parts!
- Christian Bruer
Holy Moly Nicolas, that comes out better and better. The searchlights, the boats, the fidly rangefinder - amzing!
May I asked that before, what kind of glue do you use to glue the styrene parts and what dod you use to aply the glue? Looking to the photos there are no remnants of glue to see!
Happe modeling ang keep on running with your excelent work
Christian
AKA "Painter"
VMF'06 - German Gamblers
Christian
AKA "Painter"
- LE BOSCO
HI Christian
I apply my glue (tamiya extra thin)with a HI TEC tool........a thin copper wire with a loop at the end
I will take a picture of the tool
best regards
nicolas
best regards
nicolas
- mima
- L'Arsenal
Amazing work Nicolas....
You are "Mr Scratch"
Best, Michael
Best, Michael
- LE BOSCO
Mima, for the moment ,no scratch
10 parts in resin and PE (there are no sights on the photo)
requires some patience to assemble the fourteen quad's (140 parts....)
the parts prepared for the painting
and just to be convinced to change the pieces Trumpy
the original parts are all just good to be featured on a space ship of bad SI-FI movie
we can diverted the bad parts Trumpy!!proof,remenber the last rangefinder (left
after the diverted!The first corkscrew in 350em only for the "chateau de l'erreurs"
best regards
Nicolas
- LE BOSCO
we can diverted the bad parts Trumpy!!proof,remember the last rangefinder (left
best regards
Nicolas
- Dave Rowe
Wonderful Nicolas, very enjoyable watching this build unfold
- LE BOSCO
thanks Dave!
There is a place or is possible see your Glasgow Oil Tanker?
amiti�s
Nicolas
amiti�s
Nicolas
- Dave Rowe
I'll sort out a picture or two, Nicolas. I'm in the process of building it with a full lower hull.
- jeroen zuiderduin
Hi Nicolas,
Although I'm actually a carrier fan, some ships I do find interesting, like yours. Very nice 'work in progress'.
Jeroen
Jeroen
- LE BOSCO
Thanks you Jeroen for your comment and your interest for my ship
Dave
I look forward to see your work
bye
nicolas
Dave
bye
nicolas
- Jean-Paul Binot
What is truly eye-opening following Nicolas`s remarkable build is to realize how poor the original Trumpeter kit actually is. The effort to turn this dog of a kit into a masterpiece is all the more commendable.
Mille bravos et bon courage � notre ami Nicolas !
Jean-Paul Binot
- LE BOSCO
HI jean-paul
thank you for your comment,but, I will end up blushing....it is true that it takes time to correct any errors,and I want to thank everyone who read and participated in this long,long,long ,long thread
it helps them feel less alone
Jean Paul,vraiment content de lire et de t'avoir vue a telford
amiti�s
Nicolas
amiti�s
Nicolas
- LE BOSCO
Hello all
The latest news, the last pieces freshly molded
the turrets of 380 , the range finder located on the top of the funel, guns of 100, cranes, and a carrot with parts of the crane (desk, drive wheel, pulley)
the crane assembly
Now! it looks like something
and finally, just like that, and because it's been a while since I await the moment
One turret assembly (provisionally) and in place, next to the original
it's all for now,soon the new parts
best regards
Nicolas
the crane assembly
best regards
Nicolas
- Dave Rowe
C'est magnifique!
- LE BOSCO
merci Dave!
for your comment in french
friendship
friendship
Dino Carancini
Admirable dedication to details, I'm following with interest!
Bravo!
Dino
Bravo!
Dino
- LE BOSCO
HI gents
Thank you for your kind comments
I started mounting the 20mm guns by the conical guns mounts (four parts for each)
as I'm only twenty guns mounts for my version(1952) of Richelieu (against fifty in 1943),I can afford the detailing of the guns of 20mm.The PE of l'Arsenal is very good for the scale ,but ,I'll try to give volume to the guns
My first try (in white ,mine...)
And to better realize,one of each on a gun mount
l'Arsenal
mine
and to better realize of the scale
Do not hesitate, if you have an opinion on the subject(redo them or not)
best regards
Nicolas
l'Arsenal
mine
best regards
Nicolas
