Firstly, I'm stupid and secondly, I need glasses ...
Thanks to the many tips from modelling friends, I know that I had misinterpreted McKay's drawing. Of course it is correct
So here comes another demolition.
In the meantime, I no longer print the blocks sorted by type but by yard. There are still some blocks missing, but 2 of these sets contain everything for the main yard.
Slowly it is routine and goes quickly by hand, glueing one rope into the groove of the block ...
... then the second one into the other, so that the short ends are diagonally opposite each other.
Then the whole thing into the holding device, a drop of superglue in the middle and press them together vertically ...
... and horizontally with a pair of strong tweezers.
Then tie a safety knot close to the block.
Then cut the short ends as short as possible.
Then set the averaged length for the short loop, bring the rope to length, and fix it with a drop of glue and press it together again with the tweezers.
Check length.
Adjust long loop and do the same.
Then the whole thing should already be stable enough to make a trial fit at the place of use - here it is fitting.
Then, with the specified distance of 4 mm from the block, set a knot with long enough ends for the binding and then line up normal knots close together alternately at the top and bottom all the way up to the block. It's quick and, unlike the standard wrapping, nothing slips out of place.
Add a little paint to defuse the white glue spots ...
... and two neat block strops are ready.
Still tying up the lanyard ...
... set the whole thing in place and sew in the lashing with a needle. The inner lying sheet block had already found its way to the yard
After that, it was the turn of the clew garnet blocks.
And then one can recoice
Hopefully it fits this time
XXXDAn
