USN modern colors
lascar
USN modern colors
Post by lascar »
Can somebody help me to find the good paint for the hull and the deck of a USS TICONDEROGA class ship? Humbrol, Tamiya or Gunze color .
Thanks :thumbs_up_1:
Reason: Stickied as it's an FAQ
BombMagnet
Re: USN modern colors
Post by BombMagnet »
I was just about to ask this question, though I am also open to Model Master acrylics, Vallajo, and Revell Aquacolor. Thoughts anyone?
Russ2146
Post by Russ2146 »
This chart covers pre-war and WW2 but not for all brands. http://www.internetmodeler.com/2003/jun ... part_1.htm
Post war, The specification for modern USN Haze Gray is FS 26270. Testors Modelmaster Neutral Gray is FS 36270. The difference in the first digit is satin vs flat.
Testors MM Gunship Gray FS 36118 is a good match for deck gray. New flight deck non-skid is matched well by MM Engine Gray, FS 36076.
I don't know if Tamiya, Humbrol or Gunze include the FS number in their labeling.
Here's charts put out/hosted by Int'l Plastic Modelers Society-Stockholm.
http://www.ipmsstockholm.org/colorchart ... _gunze.htm
http://www.ipmsstockholm.org/colorchart ... umbrol.htm
http://www.ipmsstockholm.org/colorchart ... tamiya.htm
All that being said, WEM Colourcoats, based on Snyder&Short color charts are considered the most accurate by many.
domi13
Post by domi13 »
Russ2146 wrote: Post war, The specification for modern USN Haze Gray is FS 26270.
And is FS 26270 convenient for a Vietnam era haze gray?
for a Essex SCB27c hull for example?
And would the FS 36118 be a good match for her flight deck?
domi13
Russ2146
Post by Russ2146 »
FS X6270 is the color. X is a 2 or a 3, depending on the sheen of the paint that it labels. If the paint you find does not have the sheen that you want, get it anyway, apply it, and then overspray it with a clear coat in the sheen you want to end up with. Note that decals adhere better to gloss, so if flat paint is what you can find, use it, spray on a gloss clear coat, apply decals, spray again with flat clear coat.
I'm not altogether certain about the flight deck since I'm not into mobile air strips, what I posted before was what I found when I searched the subject earlier. I believe that flight deck finishes have changed over the years, and then you have the effect of weather, which includes the effects of flight ops. The following pictures are of the era
Maybe someone else can chime in on flight deck color
BombMagnet
Thanks to sgtryan13 for the tip, Tamiya German Grey appears to be a great color for USN modern flight decks (pre-weathering). I would imagine it would also work for most horizontal surfaces, too.
Regarding the main color of USN ships, is it my imagination that they appear slightly blue-ish? I have looked over many photos, and have yet to find a satisfactory color in the Gunze/Tamiya line. The closest acrylic I have found is Medium Grey (Testors Model Master or Revell Aquacolor). Both appear slightly blue-ish, though the Model Master version is a little darker.
John Snyder
Post by John Snyder »
We have the modern USN colors accurately matched and available in our Colourcoats enamels:
M 03, Modern USN Haze Gray;
M 04, Modern USN Deck Gray;
M 05, Modern USN Flight Deck Gray;
M 06, Modern USN Antifouling Red.
https://resolutionhobbies.com/collectio ... avy?page=3
Reason: Edited to reflect latest seller of Colorcoat paints
John Snyder
Shady Grove Farm
lascar
Post by lascar »
thanks guys !!!!
I have order my WEM paint :thumbs_up_1:
mister me
Post by mister me »
and what about the blue antifouling on USS Port Royal ?
John Snyder
Photos I've seen lead me to believe it's very close to the prewar USN True Blue, which is available in the Colourcoats aircraft range.
John Snyder
Shady Grove Farm
El Santo
Post by El Santo »
Subset of this question: Does anyone know how (or indeed, whether) modern USN colors differ from the neutral grays that replaced the ultramarine-based purple-blue series at the end of World War II? And if they really are different, does anyone know when the changeover occurred?
Copying this from a reply I posted on another forum:
For Vallejo users: Vallejo has a conversion chart that includes FS numbers here: https://acrylicosvallejo.com/wp-content ... 7-baja.pdf
For Haze Grey FS 36270, the Vallejo Model Color match is 70.870 Medium Sea Grey.
For Deck Grey FS 36118, it's Vallejo 70.836 London Grey. For fresh flight deck non-skid FS 36076, it's Vallejo 70.994 Dark Grey.
EJM
Post by EJM »
Timmy C wrote:Copying this from a reply I posted on another forum:
What you mentioned, Timmy, is from the Vallejo Model Color line.
For the Vallejo Model Air Color line, I've read or heard the following:
Modern US Navy Haze Gray: Vallejo Model Air Color # 71.275 USAF Medium Gray or # 70.615 US Navy Light Ghost Gray
Modern US Navy Deck Gray: # 71.097 Medium Gunship Gray
Modern US Navy Flight Deck non-skid gray: # 71.048 Engine Gray
Anybody concur with these colors or not? Suggestions?
That looks correct, EJM. Here's the equivalent colour conversion chart for Vallejo's Model Air line: https://acrylicosvallejo.com/wp-content ... -Rev20.pdf
Haze Grey FS 36270: 71.275 USAF Medium Gray
Deck Grey FS 36118: 71.097 Medium Gunship Gray
Fresh nonskid: FS 36076: 71.048 Engine Gray
Boggles the mind why the same FS number falls under a different name, but there we go.
Bill Oreto
Re: USN modern colors- acrylics
Post by Bill Oreto »
I found Polly Scale CP Gray (yes a railroad color) an excellent match to Modern Haze Gray and UP Dark Gray (another Polly Scale railroad color) for modern anti-skid. I am a brush painter in 1/700 and I purchased the WEM Colourcoats tins brushed them on pallet and then matched. Testor Acrylic Neutral Gray another close match. Testors acrylics can be quirky to work with. Being a brush painter one never wants brush marks so I try to avoid Testors unless I have no other choices.
