After crushing defeat of Russia in the war with Japan, Russian navy need several years for reconstruction of his Navy. This was also because of the change in battleship design with introduction of the �all big gun � one caliber� battleship in meantime (keyword: HMS Dreadnought), which declassed previous designs.
Result after long time of development was the Gangut class with her 4 ships, which had a special, but not uncommon design. Second ship of this class was the Sewastopol which enteredservice in November 1914.
Zvezda brought some time ago this ship as 1/350 plastic kit. The price in Germany is about 50-60 EUR, depending of which shop sells.
The kit is well and safe packed in a carton box with fine artwork as usual. This artwork is interesting too, because it shows the correct place of torpedo net on freeboard of the ship. Kit itself represents Sewastopol in stage of 1914 / 1915. If kit is as far as correct when comparing to original I can�t rate by myself, because I have no depending sources to do so.
The plastic parts are in light grey color and look all so far very fine with no errors or other usual / often seen problems as disturbing ejector marks and so on.
Let us unpack the kit�.
Here the box with artwork and first look inside + front page of instruction.
Both half of the hull
A very fine structure of the underwater hull in my opinion�
The stand of kit, as you can see rocks�. a good idea I think and maybe I will use
Here sprue of deck parts, parts of both funnels and other things�.
A close up of the structure �. Very fine made and for me as one who always paints decks and does not use laser cut stuff a dream.
The 2 sprues which contains the turrets and other things (2 x same sprue)
The sprue with turret floors, small boats and other things � also 2 times as content
And the last sprue which contents bridge, masts, anchor chain and other things.
The clear parts for the bridge, packed together with decals�
And finally the flags made of paper � in my opinion better as being decal.
Conclusion:
Zvezda had made a very fine kit of an more unusual ship in history. I can understand that many main manufactures will have same key products, as for example Bismarck, but if someone makes such an outstanding more rare ship it is in my opinion always welcome.
As told I�m not able to rate if there is any mistake or error at ship in term of correct made for named stage in comparison to original. Also I can only tell after starting build if there is any problem given of parts not fitting together and so on. I can only say that the kit makes an awesome good looking from its parts and that they look is same great quality as they are for sure and known at other Zvezda kit � Russian cruiser Varyag.
Who wants to upgrade his kits can of course use the aftermarket. For simple upgrading with some railing are for sure several pure railing-sets of various manufactures useable. Metall guns I did not find at any of the (for me) known manufactures for this ship. Also I found no other set as the in the following named set from Pontos which includes all for the ship.
Who is not afraid by price of about 90.00 USD (as far as I know it will cost) I can recommend the new set from Pontos model for Sewastopol. This set includes all PE Parts, Brass gun tubes for main and secondary artillery, brass masts and sticks for torpedo net, one full toredonet out of silver PE and finally for all who prefer this, a laser-cut wooden deck. You see, everything what is needed for the ship�
Of course I can not finally rate here, simply because this brand new set is still on the way to me, but out of experience with other sets of Pontos and looking on pictures about, it is in my opinion impressive.
Only minus point is maybe for some people to get this set, because for example for Germany I did not find any shop for order � so direct order at Pontos or named shop in Asia is necessary here (if not having Vitamin �C� like Colleague who bought for me in Telford.
Here 2 pictures, of this set as information, I think / hope it is okn to do in my review (unfortunately I got no answer for my request to do, I think because people are all in Telford in moment / on their way back home).
Source Pontos model, full report about this set you find here in forum:
viewtopic.php?f=16&t=110538&p=529038#p529038
Christian
P.S.
I�m in own dispute with me in moment �
Because my Varyag will be ready within next week, as Warspite too and my current USS Essex build is a long time issue for several month, I�m not sure if I build first Sewastopol or if I build first IJN Mikasa + report about in work in progress � both are awesome models + awesome accessories about and will be great fun to build.
