Cutting the thin tubing
PetrOs
PetrOs Modellbau
PetrOs Modellbau
Post by PetrOs »
Hello,
I decided to replace some of the barrels of 5 inch AA guns with the pieces of thin steel tubing (coming from the medical 0.5 mm thick injection needles, which are just right in 1/350 scale). However, I have a question - how to cut the tubes right, so the opening is not deformed?
Any tips?
Petr
Richard Durham
Cutting Small Thin Tubing
Post by Richard Durham »
I use a Dremel tool with a cutting disk and then sand with a sanding stick to clean up the ends. Most Dremels come with cutting disks included. Rich
PetrOs
PetrOs Modellbau
PetrOs Modellbau
Post by PetrOs »
Hey thanks for an ultra-fast answer!
It really works, just tried it with my proxxon.
Jason M.
Post by Jason M. »
I was just having this same problem today, why didn't I think of that? I even went as far as trying to use a hack saw! :lol_3:
A ship is always referred to as "she" because it costs so much to keep one in paint and powder.
Chester W. Nimitz
les
Post by les »
Tubing cutter may work. They make a small one.
MichelB
Post by MichelB »
Insert a smaller, solid rod in the tube that fits tightly. Then you can cut without the barrel deforming. Not sure if this works for hypodermic needles, though...
Jason M.
Post by Jason M. »
MichelB wrote:Insert a smaller, solid rod in the tube that fits tightly. Then you can cut without the barrel deforming. Not sure if this works for hypodermic needles, though...
Thats friggin brilliant!
Chester W. Nimitz
Foeth
Post by Foeth »
That's how tubing is bent in real life!
Perhaps using a lathe works as well. I have one, but I took it apart last christmas....
