DIY Decals
- boomstick68
DIY Decals
My frustration level has reached it's peak about availability of decals. I am seeking guidance on how I can learn to make and print my own decals.
- boomstick68
- Cliffy B
Re: DIY Decals
Go get some blank decal paper (Testor's makes clear and white) and run it through your printer (inkjet, not sure about laser). Once dry you hit with some fixative (Future works or the can of stuff that comes with the Testor's kits works too), usually two coats or so and let dry. Then you apply like any other water slide decal.
As for making them you need to either find the artwork online or make it yourself in Paint, Photoshop, Illustrator, etc... Word can work too if you only need type, just find the appropriate font (there's billions online). Scaling them properly can be a bit of a PITA if you don't have Photoshop or an equivalent though.
If you need help with the graphics just ask.
- MM2CVS9
Re: DIY Decals
Apparently not too difficult as there are several guys in the local model club that will do it. What I need is someone to do custom photo etch. Has anyone ever tried the PE making stuff such as from Micro Mark?
EJ
EJ
" 1/700Hasegawa 45
" 1/700Dragon 44
" 1/700Trumpeter 43
" 1/540Revell vintage 62
" 1/350Trumpeter 42
Fair Winds and Following Seas
