As always, any comments or suggestions welcome
PS My BBRGN will be up next. Very soon
This should make a very nice model.CSGN138 wrote:Here is my BBRGN. I am very excited about this ship. I've been reading up on rail guns and it is some very promising technology.
I missed this point.CSGN138 wrote:I'm thinking two aircraft carrier sized plants, as the rail guns require a lot of power.
Actually, if you look at my CSGN final thread, there is one on there with F-35'sSciquest2525 wrote:I wonder if Ruevan Leopold's strike cruiser Mk 2, the variant design featuring a below decks hanger and capacity for 18 AV-8As would be viable for a strike cruiser.
I note that CSGN Mk 2s would have featured all the armament you want for your design in missile launchers and even add a second Mk 71 gun and have had armor to boot.
Reuvan Leopold ship would have qualified as a true hybrid.
The book. The Hybrid Ship argued that today's hybrid would be viable using STOVL strike fighters and heavy missile armaments and enabled independant operations like cruisers of old.
Is there a place for hybrid missile/STOVL aircraft with AMDR radar suite?
Busto, what would be the benefit of having a cogatunuc plant. I'm thinking if you go nuke you don't need a tanker. Would there be a worthwhile benefit in combining? Didn't the Ruskies do that with Kirov and didn't like the end result?Busto963 wrote:I missed this point.CSGN138 wrote:I'm thinking two aircraft carrier sized plants, as the rail guns require a lot of power.
Why not a combined nuclear and gas turbine propulsion system driving electric generators? The extra power will only be needed for a fraction the time when actually firing the rail gun. Even slowing down and diverting power to weapons over propulsion is likely to be entirely satisfactory as no amount of propulsion is going to outrun an missile or other airframe.
The issue is efficiency and flexibility in sizing the ship�s power plant. Long answer follows below.CSGN138 wrote: Busto, what would be the benefit of having a cogatunuc plant. I'm thinking if you go nuke you don't need a tanker. Would there be a worthwhile benefit in combining? Didn't the Ruskies do that with Kirov and didn't like the end result?
I am not following you.Seasick wrote:150 megawatts might be a conservative estimate. No Navy has adopted the LM6000 for service on combat vessels, rather its being used mostly for offshore drilling platforms. The GE LM2500+G4 or the Rolls Royce MT-30 are, probably, your best options for turbines for peak power, a base of your electric demand can be supplied by diesel alternators. 8,000 kilowatt alternators are available so if you have eight on board (not difficult) that will provide up to 64 Megawatts. In general they are more fuel efficient than the gas turbines and since you'll need a constant flow of electric they are a good option. The rest of your capacity can come from 4 MT-30.
