Pontosmodel 1/350 CA-35 Indianapolis Detail Up Sets
- Pontosmodel
- PontosModel
Hi All,
Tracy and Sean sent us many high Resolution photos of CA-35 related.
And during processing of 1/200 Bismarck,
Mr. Park has started to design some PE parts of CA-35 from time to time.
So this is not took much time to be released.
Both CA-35 sets for Academy and Trumpeter kit will be released at the same time.
Though both kit have their own merits and demerits, we found in Academy's favor a little.
These sets will have contents as
1. Wooden deck.
Will have wooden deck with deck-blue stained.
2. Turned brass parts:
Almost possible turned brass parts will be included...
3. Photo Etching parts
I cannot tell how many but I don't mind any limit in realizing with PE.
4. Resin.
Some parts.
Veteranmodel parts can be added in some version.
5. Dry Transfer
Water draft marks and Etc.
Releasing date:
We will try you can see this set by June.
Keep your eyes on this Thread.
If you have any suggestion or advice, please post and leave message on this thread.
Thank you
Keumho Kim
1. Wooden deck.
4. Resin.
Some parts.
5. Dry Transfer
Releasing date:
Thank you
Keumho Kim
litvin70
Re: Pontosmodel 1/350 CA-35 Indianapolis Detail Up Sets
It is very good news! My Indianapolis are ready for construction. But what about set for Tirpitz 1/350?
SeanF
A suggestion, along the lines of your 1980s Iowa-class series... How about a 1944-fit USS Portland conversion? I've been studying up on it, and a bit of resin for the different superstructure around the first funnel plus a few different gun tubs is all that would be needed beyond what's already in the Academy kit. The modeler cuts away a bit at the middle of the hull and kit superstructure, and in goes the resin. Since the kit's midship well deck has no planking (correct for this time period, for both sister ships), sanding out the splicing seam would be simple. Based on the Academy kit parts, I don't think they've planned to produce a Portland kit with these molds - so there should be little competition for a conversion set of this kind.
- Sean F.
- Sean F.
- Pontosmodel
- PontosModel
Sean,SeanF wrote:A suggestion, along the lines of your 1980s Iowa-class series... How about a 1944-fit USS Portland conversion? I've been studying up on it, and a bit of resin for the different superstructure around the first funnel plus a few different gun tubs is all that would be needed beyond what's already in the Academy kit. The modeler cuts away a bit at the middle of the hull and kit superstructure, and in goes the resin. Since the kit's midship well deck has no planking (correct for this time period, for both sister ships), sanding out the splicing seam would be simple. Based on the Academy kit parts, I don't think they've planned to produce a Portland kit with these molds - so there should be little competition for a conversion set of this kind.
- Sean F.
Well at this time we would release only CV-35 indianapolis sets.
And if this is possible it would be after Iowa WWII, North Carolina and South Dakoda classes.
Thank you
Kim
SeanF
That's quite all right. I can just stick with "Plan A" and scratchbuild my own conversion.Pontosmodel wrote:Sean,SeanF wrote:A suggestion, along the lines of your 1980s Iowa-class series... How about a 1944-fit USS Portland conversion? I've been studying up on it, and a bit of resin for the different superstructure around the first funnel plus a few different gun tubs is all that would be needed beyond what's already in the Academy kit. The modeler cuts away a bit at the middle of the hull and kit superstructure, and in goes the resin. Since the kit's midship well deck has no planking (correct for this time period, for both sister ships), sanding out the splicing seam would be simple. Based on the Academy kit parts, I don't think they've planned to produce a Portland kit with these molds - so there should be little competition for a conversion set of this kind.
- Sean F.
Thank you
Kim
- Sean F.
- Pontosmodel
- PontosModel
Yep what I can help is our CA-35 set will have Dry transfer including also ship name and number of Portland.SeanF wrote: That's quite all right. I can just stick with "Plan A" and scratchbuild my own conversion.
- Sean F.
Kim
JTninja
Too much talk, not enough photos
- Pontosmodel
- PontosModel
Yep posting photos are our favorite work.JTninja wrote:Too much talk, not enough photos
Just after some out put come we will post as soon.
But for more perfection, we would get any advice or reference from you during the procedure as other projects..
Thank you
Kim
- Angeliccypher
Any more news and photos on this one yet?
Gabriel
- Pontosmodel
- PontosModel
Many things are in test by Mr. Park.Angeliccypher wrote:Any more news and photos on this one yet?
But he decided to add more Inner frame on the main crane so he finally has broken all the test PE parts.
And now I am digging how to upgrade Trumpeter's terrible main barrels and Axis better than Academy's.
Please wait more...
Kim
warreni
Hi Kim.
Your website needs updating badly. Your list of sets is out of date.
One request, could you please make the numbers in your instructions larger as they are too hard to read for older eyes.
Warren
PS The replacement wooden deck part arrived earlier this week.
Warren
Pontosmodel2
- PontosModel
I'm now fitting with test PE for Academy USS Indianpolis.
Here is Catapult.
Crane
ladders
5" gun director
Left is Academy Right is Trumpeter...
with main gundirector
Main gundirector
Armo Rack
Boat Davit
Wind deflector
Stack
Veteran Model Resin Parts for Deluxe set.
SH Park
Pontos Model
Here is Catapult.
Crane
ladders
5" gun director
Main gundirector
Armo Rack
Boat Davit
Wind deflector
Stack
SH Park
Pontos Model
JTninja
Wow!
Hope there's a '44 version when the '44 Trumy kit comes out, that work is fantastic!
guest
amazing !!!
Mr. Park ,any chance a set for Academy Graf Spee ?,IMO is a neglected kit.
regards
regards
aptivaboy
Any chance of some new midships decking with the set? The midships area around the 5 inch guns and some of the Bofors tubs seem to have those little raised rectangles. I'm guessing that Academy was trying to simulate little antiskid or antislip surfaces. However, in my mind they really detract from the look of that area of the model, being totally out of scale. A crewman would break an ankle or two, were they that size on the real thing. Some photoetch replacement decking might do the job quite nicely, here.
- PetrolGator
Kim,
Would this fit the Trumpeter ship decently? What's the price target?
- Chris
1/700 Murdertorpedoboat Ooi
- Pontosmodel
- PontosModel
Graf Spee has been done 80%. But delayed for a long time by other schedule.guest wrote:amazing !!!
regards
JTninja wrote:Wow!
Our CA-35 detail set for Trumpeter kit is also coming.PetrolGator wrote:Kim,
But this may be for the 1945 version.
Kim
- Pontosmodel
- PontosModel
We've just tried to cover these antislip surfaces and other needless molds.aptivaboy wrote:Any chance of some new midships decking with the set? The midships area around the 5 inch guns and some of the Bofors tubs seem to have those little raised rectangles. I'm guessing that Academy was trying to simulate little antiskid or antislip surfaces. However, in my mind they really detract from the look of that area of the model, being totally out of scale. A crewman would break an ankle or two, were they that size on the real thing. Some photoetch replacement decking might do the job quite nicely, here.
Thank you
Kim
- Pontosmodel
- PontosModel
Today, we've finalized 98% of our Indianapolis detail set for Academy kit.
A few remains are decal printings and some more details on the hull.
This set for academy will be released with two grades.
The 35017F1 and 37017F1 "Advanced set"
Thank you
Kim
Thank you
Kim
- Angeliccypher
Will the advanced set contain everything from the basic set or will you need to buy the basic set and advanced set seperately?
Gabriel
