What decal paper are you using?
Bigdaddy Mark
Post by Bigdaddy Mark »
I've made decals with a few different papers, and they sure seem thick!! What paper is everyone using that is acceptable for ships and aircraft.
~ Chester W. Nimitz ~
frank2056
Re: What decal paper are you using?
Post by frank2056 »
If you're using a laser printer to print the decals (color laser printers are cheaper to operate than ink jets) or an old ALPS printer, then the best decal paper is by Tango Papa (http://www.tangopapadecals.com/). The decal material is very thin, comes off the backing easily and conforms to surfaces with no problem. He sells both clear and white backed paper.
Hallis
Post by Hallis »
frank2056 wrote:If you're using a laser printer to print the decals (color laser printers are cheaper to operate than ink jets) or an old ALPS printer, then the best decal paper is by Tango Papa (http://www.tangopapadecals.com/). The decal material is very thin, comes off the backing easily and conforms to surfaces with no problem. He sells both clear and white backed paper.
This is excellent info to have Frank! Too bad on the site says the paper doesn't work with Inkjet printers.
-Shane
Dallas, Tx
Working on: Revell 1/426 USS Arizona BB-39
In the Stash: USS Arizona 1/700 Dragon Premium, DKM Bismarck 1/700 Dragon Premium, Admiral Graf Spee 1/700 Trumpeter, & Prinz Eugen 1/700 Trumpeter
