The hull is painted and partly weathered. I beefed up the anchor chain with some stock I had, and added the paravane chain.
Thanks everybody! I used the kit windows, mainly because the Pontos set doesn't provide for ALL of the windows. And mixing the thinner PE with the thicker plastic parts just looked wrong to me, so I just ended up using the kit parts. At least it is consistent.Channell wrote:Great work so far!
Did you use the kit bridge windows or the Pontos replacements?
I think you made the right choice. I don't understand why Pontos didn't offer replacements for all the rectangular windows on the back of the bridge, flag bridge, ect.Kelly Quirk wrote:Thanks everybody! I used the kit windows, mainly because the Pontos set doesn't provide for ALL of the windows. And mixing the thinner PE with the thicker plastic parts just looked wrong to me, so I just ended up using the kit parts. At least it is consistent.Channell wrote:Great work so far!
Thanks Russ. The wood deck is very sticky and it does tend to grab hold. I have read that you can mist some water onto the back side first and that will give you a little play time to work it in. I just went straight ahead with it, starting at one end and slowly laying it down. I then burnished it down with a smooth metal burnishing tool. Like I mentioned, the fit has been perfect. I'm pretty sure it will stay down, I've experimented with some of the scrap and once it is down, it's not going anywhere. I guess we'll see what happens over time...RDC wrote:looking great Kelly.Always love seeing your work!
I have a question Kelly, regarding the wood deck.
Is the adhesive backing on those decks super-sticky? In other words.......does the stuff "grab-hold" instantly allowing NO movement for proper alignment? Also........on the flip side of that........did you feel the need to use any additional adhesives of any kind to ensure a secure bond that will last for years on end?
I ask because although I have not even ordered my kit yet.......my fear would be that over time the wood decking could lift up in places. (much like old floor tile is known to do!).
Curious what you have to say, because if YOU trust the decking to stay put........then I'm going to trust it to stay put on mine![]()
Russ
