Prop shaft colour
- MuseumGeek
Prop shaft colour
So, I am have been wondering what colour the prop shafts should be. I have seen them painted a myriad of different things on models, but to my mind anti-fouling red seems to make the most sense. Was the shaft really a shaft and it spun with the prop, or was it really a tube in which the real prop shaft was housed?
JCRAY
Re: Prop shaft colour
bottom color usually
- Perth_shipyard
the majority of ships the shaft is coated in anti fouling as the bottom
US DDG
Carrier
Frigate
US DDG
Carrier
Frigate
AT
1/72 Arleigh Burke flight iia
viewtopic.php?f=13&t=154767
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 HMAS Perth 1942
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
- MuseumGeek
Thanks, all!
biggles2
Red, really? I've seen some painting instructions saying to paint them gold!
Some builders and museum models have had the shafts as bright as the propellers, which has led to that as an "ideal" in minds. It's a bad idea in actual practice, but most model company personnel are neither model builders nor knowledgeable about ships, so the practice can get perpetuated through their instructions if they don't know better.
- Perth_shipyard
I have to add also with my working models where the shaft is exposed, I don't paint them and leave them as the stainless steel shaft, most scale RC modelers do this as the exposure to the elements for a the shafts on a model would loose their paint easily. To be accurate though they should be painted to match the hull as seen, but definitely not gold! Haha if anything have them stainless steel as the contrast works well.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
