Eduard kits for Tamiya 1/700 Yamato
JLD142
Post by JLD142 »
I have just purchased the Tamiya version of the Yamato 1/700 scale.
Shown below:
http://www.amazon.co.uk/dp/B001PYXPD4/r ... TE_3p_dp_1
I have painted many revell kits previously and now want to take it to the next level.
I am looking to purchase the Eduard kit - I can see two different ones online and am not sure what is better or if I require both.
1) The Yamato 1/700
http://www.eduard.com/store/Eduard/Yama ... ram=yamato
2) The Yamato (new tool) 1/700
Can anyone offer any insight or advice ?
On a second note, I am looking to glue my model to a oak base with the intention of styling it as the sea.
I assume the Yamato kit comes with a full hull - is there any technique to cut the submergered sections off ?
~Josh
Senkan
Re: Eduard kits for Tamiya 1/700 Yamato
Post by Senkan »
http://www.ebay.com/itm/LionRoar-1-700- ... 5d4d186ce1
That's a nice set. Pricey but nice.
Building 1/200 Nichi.'45
viewtopic.php?f=59&t=152105
Tamiya's 1/700 Yamato does not come with a full hull - it is waterline only, so you don't have to worry about cutting anything off.
On the other hand, if you want to portray her in heavy seas, that means you might want to add some visible lower hull.
For the Eduard PE, you'll want the newer one (17016) since it's sized for the kit you're buying, as opposed to the other one that's sized for previous tooling of the kit.
JLD142
Post by JLD142 »
Thank you very much ! :)
Join one of the fastest growing scale model showcase websites at:
http://www.complete-models.com
