rotateing radars
medic22
rotateing radars
Post by medic22 »
Iam asking for some help iam trying to make the sps48&49 on my carriers to rotate any help would be grateful
ed some hrlp I am trying to mske thr sps48&49on my carrirrs rotste. Iam
ssking for
someideas in figuring out this issue. .o
GazzaS
Re: rotateing radars
Post by GazzaS »
At the minimum you will need a small electric motor and a reduction gear. Small pulley turns a larger pulley with a belt or chain. The large pulley is at the base of the shaft attached to your radar. The shaft will have to be fixed so it doesn't wiggle or rattle. Bearings fixed to your model would be a wise investment.
Your first step should be your local R/C hobby store. They may be able to save you a lot of wasted time and effort.
Good luck!
stash:
1/350 Grosser Kurfurst by ICM
1/350 Seydlitz
marijn van gils
Post by marijn van gils »
I would look into model railroad stuff. They have an amazing amount of moving accessories to make their landscapes come alive, using electrical motors, and I'm sure you can find something with an axis which turns at the right speed.
If it doens't have a battery attached, you will have to connect this to a battery of the right voltage (or fit a resistor), and an on-off switch of some sort. These are all easy enough to obtain and connect. Deciding on the best location for the switch will be another matter!
Marijn
medic22
Post by medic22 »
Thank you for ideas the advice iis a start. In the right directiowill keep you updated
Harquebus
Post by Harquebus »
Since we don't know your precise application or what your vessels have in terms of radar, in general you will need a hollow mast or a tube to run a small wire drive shaft through. Locate the gear motor under the superstructure and connect it to the drive shaft and to the radar.
This gear motor is just for an example of what you could use: http://www.robotshop.com/en/solarbotics ... motor.html: GM17 228:1 Gear Motor w/Offset Shaft. Product Code : RB-Sbo-41 by Solarbotics
It specifies 32 RPM at 6V which is about radar speed. It is not fast but slow and steady. Lower voltage would slow it down even more and the reverse is also true.
EDIT: whoops, I necroposted here. Disregard.
~Harq
