Marking the Water Line
Harpy
Post by Harpy »
What's the best way to mark the water line on a large ship. I tried to mark the bow and stern points then taped between them marked the points, but there was enough flex in the tape to throw it off. Would a laser level work? The hull is around 3' or 4' feet.
Jim
Re: Marking the Water Line
Place the hull flat (waterline parallel) on the desktop, then attach a pencil to a solid block (wood or plastic - anything rigid). Make sure the block is of a height needed to get the pencil to the desired height on the hull. Then move the block around the hull so the pencil traces a level line along the waterline.
Olaf Held
Post by Olaf Held »
In addition to Timmy's explanation:
Video
Happy watching ~ olaf!
Harpy
Post by Harpy »
Thanks guys.
