Ahoy sergentx - help needed
biggles2
Post by biggles2 »
I wish to make this dio an action one. This is a couple of seconds after initial impact. It needs more spray, probably with cotton. How would you suggest I do it?
Scale is 1/700, using a Dragon Benson class, and a Flyhawk type Vll Uboat. I still have a few small bits to add, especially crew figs - the size of fleas! Somewhere in the Western Approaches. This particular dio is ficticious, but inspired by the Buckley vs U66. :wave_1:
Cliffy B
Re: Ahoy sergentx - help needed
Post by Cliffy B »
VERY nice!!! :thumbs_up_1:
K494
Post by K494 »
Great work. :thumbs_up_1:
K494 HMCS Arnprior
Royal Canadian Navy
biggles2
Post by biggles2 »
Thanks guys! :cool_1:
biggles2
Post by biggles2 »
Where's sargentx when you need him - on furlough? :big_grin:
sargentx
Post by sargentx »
That's a great looking little dio. I would simply use rayon cotton batting to create 'spray' at the impact point. I'd then go with a small brush and some high gloss liquitex varnish and just lightly touch the outside surface of the puff with tiny dabs. It's in one of my tutorials in this section. thanks for sharing
Every time the PE sticks to your tweezers, you lose a minute off your life.
biggles2
Post by biggles2 »
I had second and third thoughts about this. Since the action takes place several seconds or a minute after initial impact, the crash spray should have subsided by that time. Maybe just a lot of run-off from the exposed destroyer's hull, made with cotton bits and acrylic. What's your opinion on this? :wave_1:
sargentx
Post by sargentx »
agreed. I'd keep any explosive whitewater small just as a touch of energy.
