Parts Picture Request 1/200 Missouri
Thomas E. Johnson
Can someone that has the 1/200 Missouri model, please post some photos of the stock kit anti-aircraft guns? Thanks in advance.
- steinerman
Re: Parts Picture Request 1/200 Missouri
Larry Steiner
- steinerman
OK Tom, here are pictures of the AA guns that comes with the 1:200 Trumpeter USS Missouri:
First, here are shots of the parts that make up the 20mm Orlekons:
I'm not sure what the max number of photos you can have on 1 post, so I'll show the 40mm Quad Bofors in the following post.
Larry Steiner
- steinerman
Here are the pictures of the 40mm Quads:
Hope this helps you -
Regards
Regards
Larry Steiner
Thomas E. Johnson
Thank you for posting those. Should I decide that I want to buy and build this particular model, I'm still unsure if I would use all of the upgrade sets or just stick with the kit included parts.
For my 1:192 Alaska CB1 I used the Pontos mod's of the stock 40 mm, which replaces many parts of the mounts with PE to good effect. The Veterans Models 40 mm quads are probably even better. The 20 mm by Pontos are quite spectacular if a bit fussy to assemble in quantity.
