Removing Acrylic Paint
BombMagnet
Post by BombMagnet »
Anybody got some tips for this? I have some Vallejo Model Air & Model Color that needs to be gone.
Jon C Ryckert
Re: Removing Acrylic Paint
Post by Jon C Ryckert »
I have had good luck just soaking what ever I need stripped in Windex window cleaner. I had to redo the deck of my 1/350 Tamiya !-400 and all I did was keep the deck wet with Windex and with occasional scrubbing with an old brush, the paint was of in about 10-15 minutes. About ten years ago, I took the paint off of an 1/350 Essex class carrier by spraying it with oven cleaner and sealing it in a trash bag. I left it in the bag over night and most of the paint was off after the first try. I don't care for that method as it was unhealthy and nasty. Have heard that some have had good luck doing what I did with Windex but, instead they used Simple Green. Hope this helps you in some way.
Cliffy B
Post by Cliffy B »
I've used Simple Green to get Model Master Acrylics off in the past to good effect. Put them in a plastic tub and sprayed the stuff on full strength and let it soak for a good half a day to a full day and then scrubbed with an old tooth brush and rinsed. Had to repeat it a few times depending on the thickness of the paint but it came off easily.
BombMagnet
Great, thanks! That is something I can definitely give a try.
tmodelarmy
Post by tmodelarmy »
brake fluid DOT3
On the workbench:
1/350 Mikasa + Basic + Super details set (all Hasegawa)
1/350 Varyag (Zvezda) + Eduard detail set
jaymz
Post by jaymz »
i've used denatured alcohol... soaked the kit for a few hours.
also used an old toothbrush (soft bristled) to scrub it off and rinse.
HTH
ALL 1/700 WIPs & Queued... nothing finished! LOL!
Eric Bergerud
Post by Eric Bergerud »
I stripped a 1/48 TBM - a big plane - using ISP and a tooth brush. It was a mess, but didn't take that long, especially if a little residue is okay when painted over.
Eric
Hank McCoy
Post by Hank McCoy »
I use Tamiya acrylics. One day I noticed how easily my wife's gel hand soap took it off my hands . I have a big jug that I put empty bottles in with water and soap, leave them for a while and they rinse out very easily. Hardned paint takes a little scrubbing.
garyrunnalls
Post by garyrunnalls »
For styrene and metal I swear by Dot 3 Brake fluid, then rinse in dishsoap and distilled water. Not good for resin, makes it rubbery.
WigWag Workshop
Post by WigWag Workshop »
I get great results using Purple Power, which is basically a stronger windex type cleaner. I also use it for kit chrome parts.
davidwaples
Post by davidwaples »
With Vallejo another vote for Windex window cleaner.
Dave
