Bonding styrene to wood or GRP
Porteng
Post by Porteng »
Hi All,
I would really appreciate it if anyone could tell me what would be the best glue to bond styrene to wood or GRP? I am working on a fleetscale type 45 and I have made the back panel (aircraft hanger panel) from styrene sheet and I plan to bond it to wood supports and the edge will bond to the GRP hull. I've done some tests and epoxy just peels straight off the styrene.
Ben
Admhawk
Re: Bonding styrene to wood or GRP
Post by Admhawk »
Rough up the styrene surface a bit with sand paper and use medium Cyano acrylate glue (crazy/instant glue) use a little accelerator on the edges to cure it and it should be good to go. Be generous when applying to get a good bond.
Darren (Admiral Hawk)
wefalck
Post by wefalck »
Degrease carefully and roughen the styrene sheet, then epoxy resin should hold.
Eberhard
Image Image Image Image
