1/700 HYUGA 1928
Aphres
1/700 HYUGA 1928
Post by Aphres »
Basically the hull is half scratch building, some under-waterline parts are from
Fujimi's 1/700 ISE kit and have been modified.
Brett M
Re: 1/700 HYUGA 1928
Post by Brett M »
Looking really good so far on your build. I'll be paying attention!
Brett Matthews
blacman
Post by blacman »
nice project!!!
looking forward for more! :thumbs_up_1:
...in my shipyard...
Aphres
Post by Aphres »
Thanks guys?
Things are coming?
I made the PE turrets because Fujimi's turrets of ISE Class are not in correct shape. The upper armor is made of 5 armor plates but not three. What�s more, PE�s able to emphasis details of armor plates placement.
Although according to the alteration record the torpedo defence nets were removed in 1927, the net-supporting sticks and side walks can still be seen in fotos of her 1928 appearance.
Propman
Post by Propman »
Sea chest, who does that :cool_2:
Keith
Joe Simon
Post by Joe Simon »
Wow!!! :woo_hoo:
Aphres
Post by Aphres »
PetrolGator
Post by PetrolGator »
This is utter insanity of the best sort. Following your builds is so much fun!
- Chris
1/700 Murdertorpedoboat Ooi
Goodwood
Post by Goodwood »
Sweet magnificence... :thumbs_up_1:
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
Aop Aur
Post by Aop Aur »
That is a LOT of brass! For a 1/700 model, this is too nice!! Foot rails and rivets on the funnel make me frustrated as to why I cannot do it in 1/350! I assume you drew all the PE parts? I would love to get some tips of how to start, as it will be helpful for my scratch-build projects.
I can't wait to see how it turns out after a coat of primer!
:thumbs_up_1: :thumbs_up_1:
Aop
Nice!!!
mpgl62
Post by mpgl62 »
Aphres wrote:Thanks guys?
:big_eyes: :worship_1: :worship_1: :worship_1: :worship_1:
A question:
Where you bought the generic wood deck?
Atma
Post by Atma »
Awesome work ! Keep it coming.
blacman
Post by blacman »
this is what I love.....
PE world !!
fantastic so far! lookign for more :thumbs_up_1: :thumbs_up_1:
Aphres
Post by Aphres »
Aop Aur wrote:That is a LOT of brass! For a 1/700 model, this is too nice!! Foot rails and rivets on the funnel make me frustrated as to why I cannot do it in 1/350! I assume you drew all the PE parts? I would love to get some tips of how to start, as it will be helpful for my scratch-build projects.
Aop
:wave_1:
When you cut down those rails from the frame, mind the linking parts. Leaving some �long feet� on the rails and digging some small holes on the funnel or whatever parts will help you assemble them easily. For me, drawing and using PE parts make the situation even more simple for what I have to do is just drawing some holes on funnels and some �long feet� on rails and sticking in. This is so easy that I can even make rails almost thin and small enough to fit the scale.?feet on my PE rails are 0.2mm long while the actual dimension is 14cm?
Aphres
Post by Aphres »
A question:
Hi :wave_1:
The wooden decks are not products on sell. Most wooden deck goods for small scale ships from the supplemental market are failed to fit the scale so i didn't use them.?in 1/700 they usually make the intervals as wide as 0.4 mm while i consider the acceptable width should be at least less than 0.3mm because for the IJN war ships the actual dimension of the wood pieces are just 14-17cm wide ?
Aphres
Post by Aphres »
blacman wrote:this is what I love.....
PE world !!
Many thanks to you guys?
a little bit progress......
the catwalk and sticks for the torpedo defence net
the back side of the optical weapons storage room
I can't find any fotoes of the ISE Class in 1920s or early 1930s clearly showing this part but, the structure of these two floors is very similar?not only similar in appearance but functionally? to the same part of KONGO Class in corresponding years so I made the voice pipes on the back according to a foto of HIEI in late 1920s.
Joe Simon
Post by Joe Simon »
Another unbelievable build!
J. Soca
Post by J. Soca »
This is very impressive! :thumbs_up_1: :thumbs_up_1:
Jose :wave_1:
Aphres
Post by Aphres »
Hi everyone!
I bought the optical weapon set from "Shelf Oddity". It has really amazingly nice details!
This is how the bridge looks after installing part of the optical weapons......
and some fittings......
Return to “Completed Models”
