Attaching 3D printed parts to styrene parts?
CWatson
Post by CWatson »
I am not much of a after market part type of person but I have found many of Trumpeter USN kits have 20mm guns that lack shields so I bought some Blue Ridge 20mm 1/700 scale guns.
What is the best way to bond these materials? If it is Super or Crazy glue (CA?) is there a specific brand because in my experience the attachment point become brittle and separate over time.
Thanks again,
CW
bioshock73
Re: Attaching 3D printed parts to styrene parts?
Post by bioshock73 »
I have both Blue Ridge (haven't used them yet) and 3d Models guns in 1/700. Krazy glue is one of the most well known brands. Have you checked Gorilla Glue or Loctite? Have you tried it in gel? Also, are you leaving a little peg at the bottom of the gun pedestal for added support? Makes it easier for the mount to remain in position while the glue dries.
CWatson
Post by CWatson »
Never tried the gel, regular Crazy Glue seems pretty thick. Yes I leave a peg at the bottom to insert into hole on deck.
CW
medicmike
Post by medicmike »
I used the 3DModelparts twin 20's, quad 40's, and 5 inchers in my 1/700 Indianapolis. I used Gorilla glue (a gel superglue) to attach them all to her and it worked just fine.
Just finished:
1/350 USS Columbia 1945
Current projects:
1/700 USS Catamount 1960
1/700 USS Helena 1942
1/350 USS San Francisco 1944
CWatson
Post by CWatson »
medicmike wrote:I used the 3DModelparts twin 20's, quad 40's, and 5 inchers in my 1/700 Indianapolis. I used Gorilla glue (a gel superglue) to attach them all to her and it worked just fine.
Thanks, I will give that brand a try.
CW
