I had earlier built the HMS Gotland in 1/350 from OKB Grigorov and started a search for the other Swedish submarine that have been made as a model.
it is HMS V�sterg�tland from Sea Wolf. It took me a couple of years but finally I got one.
It's not a very large kit in 1/350 scale.
The finished kit.
Two of the submarines in this class got modified with Stirling engines and I wanted to build one. I was lucky to find a second kit and could start on one.
This conversion fought me. After all work with putty and sanding was done I managed to break it so I had to glue it together again and start all over.
To finish it I had to make a similar propeller as on the HMS Gotland. (I made it from plastic card and the tip of an aircraft missile)
Here they are together. Gotland, S�dermanland an V�sterg�tland. They are named after provinces in Sweden.
(The Gotland build: viewtopic.php?f=60&t=152194)
