Books or more about USS Sutton DE-771 and USS Flusser DD-368
Book reviews and info on plans and other media.
Moderators: Timmy C, Gernot, ArizonaBB39, JWintjes, Olaf Held
Schiggy096
Post by Schiggy096 »
Hello together
My Name is Fabian. I live in Germany and am 20 years old. My English is not good. I will become better in English.
My brother an me will bulid The USS SUtton DE-771 and USS FLusser DD-368 in 1/72 scale.
Is there blueprints to the ships ?
Which should i buy books of USS SUtton DE-771 and USS FLusser DD-368?
Books should have a lot of Pictures.
What there is else?
greeting Fabian
Schiggy096
Re: Books or more about USS Sutton DE-771 and USS Flusser DD
Hello,
Thanks for your help.
Ich can not build a Ship wihtout Body Plan.
In german spantenriss.
There are books about Cannon Problem mahan class?
Good nigth
Schiggy096
Good morning,
Yes, but I have plan of DE Edsall class.
My friends build 3 destroyer in 1/72 scale.
The plan of mahan is good.
I need hull mahan. Ich can not build a Ship without hull in scale 1/72.
Maarten Sch�nfeld
Post by Maarten Sch�nfeld »
Hi Shiggy, Fabian,
above the body plan (Spantenriss) which is valid for all the DEs. You will have to enlarge this drawing to 1/72 yourself. Note that the vertical and horizontal grid lines are exactly 3 feet (914.4mm) apart. That is 12.7 millimeters in 1/72.
Frame 0 is at the Forward Perpendicular (Vorderes Lot in German) and Frame 16 the Aft Perpendicular (Hinteres Lot). Length between Perpendiculars (LPP, is LzdL in German) is 300 feet for all the DEs (except the Evarts class). This means the distance between two frames is 300/16 = 18.75 feet, in 1/72 that is 79.375 mm. Study https://de.wikipedia.org/wiki/Schiffsma%C3%9Fe to familiarize yourself how measurements on a ship are taken.
I recommend you to get the book 'Anatomy of the Ship: USS England', published by Conway. Above body plan is a scan from that book. In general the Buckley is similar to the Cannon class, but there are differences.
For building USS Sutton (Cannon Class) I recommend studying the website of USS Slater (also Cannon Class) very closely:http://www.ussslater.org/ If you get any more questions, pleas ask. I have more drawings of the Cannon class too.
By the way: I speak German too, if you get stuck in some language issues I can help you out there.
Roger Whittaker +9/13/2023
Return to “Books and Reference Material”
