The RFI is out, time to start whiffing....
http://www.defensenews.com/articles/us- ... ombat-ship
https://news.usni.org/2017/07/10/navy-r ... o-industry
https://www.fbo.gov/index?s=opportunity ... ode=list&=
Needs include Self and convoy defense (AAW and ASW), integration with the task force.
28+ knts
3500nm range
200 Crew or less (all inclusive)
COMBATSS-21
EASR v2 http://www.raytheon.com/capabilities/products/easr/
SQQ-89F
Nulka
SLQ-32(V)6 and capability for follow-on
1x MH-60R and 1x UAV (MQ-8C)
2x 7m RHIB
"Self Defense Launcher Capability" - (sounds like Mk41 VLS for ESSM to me...)
Mk 110 57mm gun (I'd look for Mk 45 here for versatility, but Mk 110 may be a focus for performance against small boats)
SeaRAM Mk15 Mod 31
2x4 "OTH Canister Weapon" (Harpoon/NSM/LRASM)
Surface to Surface Missile Module (SSMM Longbow Hellfire)
And more...
My first thought matches one from before - a stretched Betholf with a second Gas Turbine.
But I am still a fan of the Murasame/Takanami/Akizuki class hull.
viewtopic.php?f=67&t=50783&start=440
What-If USN FFG(X)
jasonfreeland
Re: FFG(X)
I think I'd like to see a longer range than 3500 miles would be my only major gripe. The pacific is just going to call for more range for self deployment if nothing else.
- MAJOR-B
Re: FFG(X)
this is a design that is overdue. With the increase need to have a presences in the PAC area. The navy needs a FF. The Coast Guard ship would be the logical point to start with since the U.S. has the rights to that design. She would need to be stretched to at least a Spruance size platform to handle all the missions they want it too. I know the JSMDF DD103 and DD 116 class are great platforms and have the great potential for a what-if model. However my thoughts are see if they could play with the Spruance design to have the 110 mm aft and 5 inch forward. VLS should be ESSM, ASROC only, harpoons and for electronics I think the NTDS Suite would be the best. Omit the MK-29 launcher and go with either the sea ram and have the CIWS instead of millennium gun..
- SumGui
Re: FFG(X)
https://news.usni.org/2017/07/27/navy-h ... quirements
"you need something in the 70 to 75 range on small surface combatants to be able to fill out the requirements from the combatant commanders around the world. And I would like to see this to be a robust ASW, anti-surface design with a 6,000-mile range. I think that that�s a good starting point.�
On the 6,000-mile range issue, the RFI notes the �minimum distance the ship can sail without replenishment when using all of its burnable fuel� is 3,000 nautical miles while sailing at 16 knots. Hendrix told the SASC subcommittee that �given the reserve fuel requirements, because we�ve never run the ships all the way down to zero, we always want to keep fuel for ballast and emergencies, that would actually limit that ship to have to at least take one refueling for even a transatlantic convoy escort. It would seem to me that any type of ship that�s built, and it�s written into the document, needs to be able to do [anti-surface warfare], anti-submarine warfare and convoy escort, that it ought to be able to do convoy escort without having to peel off and hit the tanker on the way over"
- SumGui
Re: FFG(X)
Some Type 26 data for comparison/consideration:
https://ukdefencejournal.org.uk/bae-vid ... abilities/
"The Type 26 will undoubtedly be the most capable ASW afloat, arriving early next decade. But it�s so much more than an ASW platform, with the ability to take Tomahawk strike missiles, a 5-inch gun and a considerable local area defence capability; and the mission bay, which can take a whole range of mission support packages."
https://ukdefencejournal.org.uk/bae-vid ... ign=social
AndyM
Re: FFG(X)
It's frustrating they leave this open to modified LCS as the propulsion plant will be vastly inefficient compared to a plant and hull designed for the speed profile anticipated. The NSC frigate variants come close. My biggest concern is they are budgeting for a ship to cost over a billion each.
