1/350 Suffren (1899)
Chris Meddings
Ship Modeller Magazine
Post by Chris Meddings »
This is my latest, a 1/350 full scratch Suffren, as she was at the time of the Dardenelles campaign.
This is around 80% built. Still have the davits, boats and a lot of other stuff to make and add. A lot of this is also dry-fit, so its a little wonky on the bridges until they are finally set in place permanently
Last edited by Chris Meddings on Sun Sep 16, 2018 3:38 pm, edited 1 time in total.
JIM BAUMANN
Re: 1/350 Suffren (1889)
Post by JIM BAUMANN »
that looks great Chris!! :thumbs_up_1: :thumbs_up_1:
good looking ship!
Chris Meddings
Those are the drawings I�m working from, pls a lot of photos
The props I know about but haven�t got around to adjusting. What other differences?
Chris Meddings
Thecstacks, and a lot more besides: are not finished yet
JIM BAUMANN
Re: 1/350 Suffren (1899)
Hi Chris
My inner pre-dreadnought French Battleship fan persona has re-awoken...
a small point and at this stage entirley corrigible when you draw the PE
but the stern-walk railing was vertical close sace railing not solid
( North star do the very item in 1/700 but I do not know if available in 1/350...)
see image of Suffren rear below
HTH-- and watching with great interest :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Best wishes
JB :wave_1:
Chris Meddings
Hi Jim
The railing PE was drawn exactly as the real railings but sadly did not etch completely (particularly the rings at the top)
However it looks better in real life than it does here a wash during painting will bring the detail out better
Chris Meddings
This shows it better
Very impressive work!
Dan Banks
Post by Dan Banks »
Looks like your making a kit. If so I�ll buy one
Chris Meddings
Sorry I�m not. It would cost a lot of money to turn this into a kit, to cast it etc. And I don�t think it would make the money back, so this is just a one off
Miguel
Post by Miguel »
This is stunning ,Chris thanks for share your work ,I love old battleships and those french pre dreadnoughts are awesome , this one is turning in a fantastic build :thumbs_up_1:
No Whine Policy
1.- Modify it
2.- Ignore it
3.- Don't build it
marijn van gils
Post by marijn van gils »
Fantastic work Chris! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
As another French pre-dred-fan I'm really hapy to see you scratchbuilding one of these monsters.
So I'll be following with great interest.
Ready for SMC? :big_grin:
Chris Meddings
I hope so, but then I have to fly with it to Amsterdam and a bus to Eindhoven :O
marijn van gils
You should have chosen 1/700 scale... :big_grin: :big_grin: :big_grin:
Chris Meddings
Size is not an issue. But the PE is quite delicate
Joe Simon
Post by Joe Simon »
Very impressive!
marijn van gils
Chris Meddings wrote:Size is not an issue. But the PE is quite delicate
A wooden transportation box made to size (and able to fit in overhead compartments on an aeroplane) is the perfect solution for this. It takes only a modest effort to make one (it doens't need to be fancy), and you will be able to use it for many models to come. I have several at home I made for transporting figures, and for every diorama I make a custom-fit box. It also makes transport by car much more hassle- and breakage-free.
Fix the model inside so the box can be turned upside down without problems. A good amount of Blue Tack is usually sufficient.
Also, make sure you can easily open the box, because the security staff at the airport always wants to know what is inside... :)
A transparent plastic box is a good alternative, and has the advantage that the security staff can readily see the contents (and you don't have to build it!). But of course, you have to find a suitable one: correct size, strudy, firmly closing lid, and easy to carry.
You see, I accept no excuses not to bring this one along! :big_grin: :big_grin: :big_grin:
Cheers!
Marijn
Chris Meddings
I had one exactly like that made after �the incident� with the scanner on the way to kmk
Last year :O
marijn van gils
And you know who had a similar incident this year at the Eurostar security: Spencer Pollard!
The staff tipped his box over, in which the models were only held in place with toothpicks on styrofoam. He spent part of the friday evening gluing back broken bits... :Mad_6:
Rudi Meir had it happen too when flying to the USA many years ago.
Styrofoam and toothpicks are a very common way of fixing models in their carry-box, but IMHO is not safe when passing security-checks...
Cheers!
Marijn
