Does it make a difference?
- DeadByCheese
Is there a difference between different color primers?
Noob Modeler
Current Projects
- 1/350 Yamato
- 1/700 Hyuga
Wants/Future Projects
-1/350 Nagato
-1/350 Yukikaze
-1/350 Akagi
Current Projects
- 1/350 Yamato
- 1/700 Hyuga
-1/350 Nagato
-1/350 Yukikaze
-1/350 Akagi
- les
- Devin
The tonal variations that Les mentions are probably the biggest concern you have.
That being said, though, there can be difference depending on which brand of primer you refer to. The Krylon spray can primers, for instance, are different. The black and ruddy brown primers are meant to be sanded. The dark gray is not. You can still sand the dark gray stuff, but it's not as easy and will clog up the sandpaper much quicker.
-Devin
-Devin
- PetrOs
- PetrOs Modellbau
I use Gunze's Mr.Base White 1000 with paintbrush or airbrush, and happy with it.
Further kits in preparation.
