curves
Rob J
curves
Post by Rob J »
Does anyone know a good way to mask tape around curves?
The Black Dragon
Vlad
Post by Vlad »
I would mask a large area with wide tape then cut the curve out using a knife.
Vlad
kevinb120
Post by kevinb120 »
Are you doing a large curve on a large surface or have a very small piece that is curved???? Vlad's answer is perfect for doing camo on a ship, make patterns on glass and cut. If you want to mask anti-glare panels on small aircraft noses you use Parafilm M. Whats the project???
