How do I make believable canvas blast-guards for the 9 main and 6 secondary gun batteries?
HELP!
Thanks!!
Boy, between that anchor thread and this one all the comedians are coming out of the woodwork. Would have preferred not to be pinged to a pointless (non) reply to my question, if you don't mind.DeadByCheese wrote:Use Canvas?
Lol, no idea.
bucketfoot-al wrote:Boy, between that anchor thread and this one all the comedians are coming out of the woodwork. Would have preferred not to be pinged to a pointless (non) reply to my question, if you don't mind.DeadByCheese wrote:Use Canvas?
Lol, no idea.
If you want to see Yamato Ten-Go 'museum' accuracy in 1/200 scale, just wait til I'm finished dude....
ingura wrote:I'm pretty sure you thought about sculping them with epoxy-putty. This would be my choice.
Another idea is the thin aluminium sheetmetal one uses in the kitchen. It worked pretty good on my lifeboats, though they were 1/100 scale. Anyway - I took a napkin size piece of this, formed a ball and unfolded again to get a "used" texture. After that it was brought into shape and glued on the item with epoxi.
I actually just had a wild idea. I don't know if this would work or not, but I'll try to explain...DeadByCheese wrote:Use Canvas?
You know stuffing the edges of the cloth inside the turret opening (except at the top where it has to cover the blast support hatch just might work.ArizonaBB39 wrote:I actually just had a wild idea. I don't know if this would work or not, but I'll try to explain...DeadByCheese wrote:Use Canvas?
Don't shrug off using canvas or some other type of cloth just yet. My idea is this:
Find a fabric that is the correct color or can be dyed to such or is to your liking. Cut three squares (I don't know, about 2cm by 2 cm??) and punch a hole for the barrel in the middle of the fabric. Slide the fabric down the barrel until it is in the correct place on the barrel itself and fasten it somehow (super glue??). Next, push the remaining cloth into the gun turret and fasten just the edges of the cloth to the inside of the opening of the turret where the barrel sticks out, once dry push the cloth back out of the opening and maybe you will have a realistic looking blast bag and have both a blast bag and barrel that can move!
I have no idea if that made any sense, or if it will work, but, like I said, it was just a wild idea I had. At this scale it might just work...
Roy you are a genius! I was wondering how to get the 'blast covers' into the correct shape. A loose frame will do the job while allowing the guns to still move up and down!roy allen wrote:The cloth your after for this is ladies pure cotton hankies, the large male one's are too thick. The older and more washed they are the better. Cut to shape but over size to give you plenty spare. Next make a small wire frame that sits over the turret gun entry port, attach the frame to the cotton sheet at the rear and gently slide over the barrel, use tiny amounts of super glue at all times and go slow. If you wish you can also make a small ring for the front of the bag.
Hope this helps
Roy
Don't worry Roy, I will. Incidentally, GPM out of Poland offers not only the 39 main and secondary Yamato guns in METAL for $12 USD (which I have already mounted), but also an incredibly detailed photoetch set of 6 .25 cal machine guns - I just ordered 9 sets - enough to outfit the entire ship.roy allen wrote:dont forget to post some shots at 1/200 scale they should look great,
if you had wanted a fixed gun setup the other option would be dress makers pattern tissue soaked in a 50/50 mix of water/pva glue
Forgot to say, use dry light grey artists pastels on the bags with a touch of white on high points. you'll swear the things are real![]()
Roy
Rodders wrote:![]()
Are Blast Bags really Blast Bags?
Surely the point of protection against blast is to protect the turret crew from the blast of their guns and any superfiring guns. This would require an inflexible medium. As the "Blast Bags" are flexible and move with the firing of the gun, or a superfiring gun I think these items are a form of weatherproofing to keep water out of the turret.
Of course, any retired large gun man out there may disagree.
Interesting though, eh?
