Rigging Advice for a beginner?
- Jadefalcon0
Hi guys
I need some rigging advice so I can rig my USS Arizona. I have thread and some tweezers, but I have been finding it very hard to do any good rigging. Any tips guys? I really need help. Thanks!
http://tgwnetohh.blogspot.com/search/label/Model = Model Blog Posts
http://www.maj.com/cgi-bin/gallery.cgi?f=168325 = Ship Kit Instructions
- kennylibben
- Jadefalcon0
it wouldn't hurt me if I didn't do it: but I think it would accent the model really niceley (I've already added it to an oak base). If it helps, this model is 1:426 in scale.
- Avery Boyer
I think monofilament would be best, I can't remember the company now, but it can be bought through Pacific Front Hobbies
- Francisco P. de Nanclares
- johndon
I use 'invisible' nylon thread. Attach at one end with super glue, pull gently until the thread is tight and apply a little glue and accelerator to the other end.
All the rigging in the pic below was done this way and is my first attempt at it:
Turned out to be far less scary than I thought it would be.
John
John
- Sean Hert
- bucketfoot-al
Re: Rigging Advice for a beginner?
PRAY.Jadefalcon0 wrote:Hi guysI need some rigging advice so I can rig my USS Arizona. I have thread and some tweezers, but I have been finding it very hard to do any good rigging. Any tips guys? I really need help. Thanks!
bucketfoot-al
https://battleshipyamato.com
- David Griffith
- Location: Waiting for HMS Glatton in resin. Not holding my breath!!
Go into a large fishing store and look around the fly tying shelves. See if you can find some "Caenis" thread made by Uni-Thread. This is an extremely fine (20 denier) polyester monofilament that comes in black, and is intended for tying flies on tiny hooks. In this country it costs about �1.20 for a 200 metre reel. This is not the absolute thinnest stuff that I've found to rig ships, but it's easy to use as it's on a reel.
If you can't find it locally, try logging onto http://www.fishingmegastore.com as the Glasgow Angling Centre does mail order.
I use old fashioned stationer's gum, or gum arabic from the art shop to glue my fibres onto the ship. Secure one end of the fibre to the mast or yard with a knot, take the fibre round or over its next destination and hold it under very slight tension with a piece of Blu-Tack on the base board. The gum will set in a couple of minutes and you can trim off. If you make a mistake, it's water soluble and you can take it off.
Don't be afraid. Provided you've got some patience, plenty of light and an absence of draughts, it's not too difficult to do basic rigging. It makes an enormous difference to the appearance of a model, instantly bringing it to life.
Kind regards,
David Griffith
Kind regards,
David Griffith
"For scientific leadership, give me Scott. For swift and efficient travel give me Amundsen. But when you are in a hopeless situation, when you are seeing no way out, get down on your knees and pray for Shackleton."
- PetrOs
- PetrOs Modellbau
I use ultathin antenna wire, 0.05 mm. To colorize it, I pull it between a permanent marker tip and a wooden board a few times.
Further kits in preparation.
- Jadefalcon0
Got a fishing store up the street, but I will be down in Reading this weekend and I will stop in Cabela's (can you GET any bigger??)David Griffith wrote:Go into a large fishing store and look around the fly tying shelves. See if you can find some "Caenis" thread made by Uni-Thread. This is an extremely fine (20 denier) polyester monofilament that comes in black, and is intended for tying flies on tiny hooks. In this country it costs about �1.20 for a 200 metre reel. This is not the absolute thinnest stuff that I've found to rig ships, but it's easy to use as it's on a reel.
- J. Soca
- Dustermaker
Im almost 100% sure cabela's will have it, its one of the greatest stores on the planet when it comes to fishing. Only a large bass pro shop can come close.Jadefalcon0 wrote:Got a fishing store up the street, but I will be down in Reading this weekend and I will stop in Cabela's (can you GET any bigger??)David Griffith wrote:Go into a large fishing store and look around the fly tying shelves. See if you can find some "Caenis" thread made by Uni-Thread. This is an extremely fine (20 denier) polyester monofilament that comes in black, and is intended for tying flies on tiny hooks. In this country it costs about �1.20 for a 200 metre reel. This is not the absolute thinnest stuff that I've found to rig ships, but it's easy to use as it's on a reel.
I will miss you Werner. Fair winds and following seas.
