Wanted: large gun barrels
- MichelB
For a joint operation scratchbuild with a friend of mine, where can I get 1:16 turned metal barrels for armour? Specifically for a SU-100. T.i.A!
ingura
- Jose Chaica
- MichelB
ingura
What I expect is that you need two barrels in a diameter not exceeding 10 mm. Forget PayPal - we're not talking money at all, ok?
Here is what I did for a friend: 15"ers of WARSPITE in scale 1/100
One perfect plug, the rest casted resin.
- Jose Chaica
- Jose Chaica
Hi Peteringura wrote:Thank you Jose - what kind of gun barrels are you looking for?
I was looking for someone to turn me 1 (I need 9, but would cast all the others by my own) Baltimore class cruiser 8�(203mm) L/55 in 1/72. It�s quite difficult to find someone here in Portugal willing to do that. Building such a ship is something I�ve been holding up, since I can�t find a person to do that job for me.
Thanks for asking.
- MichelB
Ingura, I did the math and the max diameter is 17mm. The entire length of the barrel would be about 25 cm, add a locator pin of about 5 cm = 30.
Perhaps you could chop it up in two with a connecting pin, but there's no discernable 'line' somewhere in the middle. I have a GIf image with all the figures worked out, but it�s on another computer right now. I can send-post it tomorrow. Do you think you can make a two piece barrel with a small enough transition=
- Jose Chaica
- MichelB
Ingura,
I've done the math and jotted down the dimensions on a technical drawing that showes the full length of the barrel. If there's one thing impressive about the SU-100, it's that ridicilous barrel jutting forward.
http://www.warshipmodels.com/~users/Mic ... _100_4.JPG
Will you let me know if you can turn this one? Your help is really appreciated!
- MichelB
Ingura, that's great to hear. Actually we will need only one barrel, with some cm's at the end to fix her into the hull. That's ok?
If you can do that, you'll have two very thankful friends in Holland.
